Question about Motorola Mobility i580 Cellular Phone
Doing a self check
My phone turns on but then fades out and gives the message: self check fail:02000 r5c.00.01
  • big smith Mar 19, 2008
    When I plug my i580 into my pc it does not reconize any devices.
  • 18 Answers
Its fatal error
pls show your phone to nearest phone repairer
Posted on Mar 17, 2008
SOURCE:
Screen fades to black will no power back up until unplugged. Before the screen goes black clicking like a replay comes from the set.
The most likely issue is that some of the solder joints are expanding and contracting and loose their connection to the board. Then the self-test fails and the tv turns off. It is difficult to say which part(s) are at fault. You would need to desolder and resolder various components on the boards. Then hope you found the correct one. (Alternatively, replace various of the boards but the bad solder joints are frequently a manufacturing issue on most of the boards.)
(Other parts that can click are the fans and color wheel of some plasma TVs. However, the color wheel usually shrieks when it fails and the TV will give an error message if the fans aren't cooling properly. Cleaning the fans wouldn't hurt but won't solve the problem.)
I wish that I had better news for you.
Jul 14, 2011 | Fujitsu P50XTA51US Television
I've received a mms message and my screen say MMS retrieval failed, how can read this message?
This often has to do with a network error, or your phone its self. The best solutions are as follows.
  1. Turn your phone off and turn it back on and attempt to retrieve the message again.
  2. If that fails, ask the sender to resend the message.
If the above solutions do not work you might need to consult with your wireless provider.
Jun 03, 2011 | Cell Phones
Motorola i335 with a message: Self Check Fail F4000 R7F.00.04. Do you know how to fix?
Self check fail needs to be fixed at a service center or by Motorola. There is also the option of taking the phone to a Sprint/Nextel service center for flashtrap and software fix.
Apr 13, 2011 | Motorola Mobility I335 Cellular Phone
I have Fender Hot Rod Deluxe and Blues Deluxe amps.After the amps are in use for 20-30 minutes, volume just flat out fades to almost nothing. I have had it checked out and technician could not reproduce...
I want you to do a test. while using the amp plug a pair of headphones into the preamp out... note you will only hear stuff on one side if they are stereo phones and the sound may be fairly weak... while the unit is operating correctely then unplug phones and use it. When it fades out plug in phones compare the level when it was OK... If the preamp output fades lower as well, then we know problem is in the preamp section...
We can do a lot of troubleshooting without opening the amp.
I see nothing in the scheamtics that should be an issue causing this...
Since it didn't fail for the tech, think "what was different?". Are you connecting something else? Foot pedal? Temperature? :Loudness of playing?
Now what else is in common to these two units... AHA! The guitar...
If your guitar has a battery in it, the 20 to 30 minutes fading would correspond to a battery failing and then recovering after you unplug the guitar for a while.
Apr 23, 2010 | Fender Hot Rod Deluxe Guitar Combo...
SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
May 08, 2009 | Nokia N70 Cellular Phone
I get an opening message: "SIM card registration failed" - what does this mean? then i can't receive nor send any msgs.
1, The sim card is turned off, if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
May 08, 2009 | Nokia 6300 Cellular Phone
Message sending failed, number not in use..
call customer care and ask them for message center number n how to put it in yor mobile model.they will assist you. If its not working goto settings and do a restore to factory settings.then it ll work fine.But this ll erase any contacts calnder entries etc etc.so mk a note for al thse before you do this.
Feb 11, 2009 | Nokia 1100
Error message for Motorola i335 phone
You need to take the phone to a mobile repair store and ahve them try to fix it for you...the board is giving errors
Nov 30, 2008 | Motorola Mobility I335 Cellular Phone
Motorola Mobility i580 Cellular Phone Logo
268 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
