This is a re-post- I did not fix the prob before...
The problem is - major audio drop outs during playback with the above hardware/software combination. After extensive research, it pretty much comes down to an issue with my notebook hardware.
It use to work fine intermitantly. 1 day I could play 5 hours straight no worries.The next it would freeze during playback with CPU @ 100%!! Then I got the pauses/ dropouts whilst playing 1 song. Now I have completely reinstalled my whole system, updated all drivers for everything (system,software and external midi device drivers) and it seems worse off!!! Just drops out for a second every few seconds. I was watching my CPU and it would spike during dropouts. Ive literally tried everything!!! I am a trainee computer techie and have access to great knowledge and resources but still haven't found a solution. I'm assuming its related to Beringer's drivers being not so universal? Also media player cant play full songs anymore? man this sux! Almost ready to convert to vinyl DJing!!!
My set up is as follows.
Asus A2500D Notebook (A2D) Mobile AMD Athlon XP-M 2.16 Ghz CPU 1 Gig RAM 80 Gig Hdd SiS PCI to USB Controller?? if that helps... DMA controller appears to have no drivers installed in Device manager??
If you guys can work this out, I will take my hat off to ya's. I have spent more than 6 months working this out!!
Good luck and thank you guys in advance. I spend a lot of time in my job giving free advice so it would be lovely for karma to come my way for a change haha Any help will be passed on to fellow sufferers!
Thank you kindly!
Comments:
Mar 22, 2008
- PROBLEM SOLVED!!!
Turns out I was correct about the SiS PCI to USB chipset. They do **** for USB audio device applications. I bypassed the SiS chipset by plugging in a Gigatech PCMCIA card w/ USB ports into my laptop. Now it runs like a dream! I spent 6 months of diagnosis and research to figure this one out so I hope this helps others with similar issues!
Thanks again guys!
May 19, 2008
- Yeah like I said, the issue was the SiS chipset. I pulled the whole CPU out, cleaned the fan, checked its bearings, reapplied the heat sink paste and still had the issue. Through in the PCMCIA card and it works like a dream now.
Turns out the SiS chipset cant handle the amount of DATA that was pumping in and out of it. Thank god for USB - PCMCIA cards! Gutted it took so long to figure it out though! Even the guys at work that have been techs for 15+ years couldn't work this one out....
Cheers for your time.
Jun 25, 2008
- The PCMCIA card fixed the problem for a while. Suddenly the other day, my the CPU meter in Traktor 3 started flickering between 0 - 1/2 way and the playback was lagging terribly! As soon as the BCD3000 is disconnected, my system runs like a dream. Although my system is only 2.4Ghz Athlon w/ 1 gig ram, it runs better than most of the new systems i build at work.
Its tough to say but I'm getting the idea that the BCD is stuffing the USB - BUS in my system. It also worries me that the BCD power supply does not have earth pin for the wall plug.... makes you wonder...
As the processor usage goes up to 100% I personally would check the fan on the processor. Does it seem to be running, does it speed up when the CPU goes to 100%. I had this with graphics cards similar fault caused by the lubricant /grease on the fan spindle drying out and causing the fan to stick or stop, and then the graphics GPU getting too hot. Also check the heatsink / vents where the air from the fan blows out. Just a thought.
Comments:
May 20, 2008
- Glad you got it sorted, you deserve it after 6 months of grief.
Was this helpful?
Yes
No
Solution #2
posted on May 19, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
my systems also is also freezing but the process dips from 60% down to 2% and then up again.... weird. m.
Just installed a new hdd 500gb on my acer 5100 and now it won't read the recovery disc. Plz help....
(More)
Just installed a new hdd 500gb on my acer 5100 and now it won't read the recovery disc. Plz help. Dwayne
when i turn on my laptop it shows the logo and the for the primary master HDD user password so i put...
(More)
when i turn on my laptop it shows the logo and the for the primary master HDD user password so i put that in. after that it say windows failed to start. A recenr hardware or software change might be the cause but i dont have the window installation disc to repair my laptop.....
