Question about Philips ID9370B/37 Phone
No ring tone
I cannot dial out and do not recieve calls and speaker phone does not come on
  • Bugg566 Nov 30, 2008
    NO RING TONE CANNOT RECIEVE OR MAKE CALLS
  • stevewarren1 Dec 03, 2008
    no ring tone cannot recieve or mike calls
If you can't mend the phone I am looking for a spare base and would be interested in buying it from you. geoffrey 07966 907232
Posted on Aug 10, 2008
Did you find a solution. We are having the same problems
Posted on Aug 01, 2008
How to recieve a fax ?
If your printer is connected to a modem make sure that the port has a dial tone. To check for dial tone, try to plug in a phone to the same port that you printer is connected to. If it doesn't have dial tone, you might want to check with your phone provider. Or you can plug in the printer straight to a wall jack.
Once the printer is connected to a line that has dial tone, you can then setup the printer to receive faxes. To set it up, on the control panel of your printer, press on Setup > Fax Setup > Ringing and Answering.
If you have an answering machine, set your printer to pick up 3 rings higher than your answering machine. If not, set it to pick up on the 5th ring that way you will still have time to pick up the phone if it's a voice call.
If you have a voicemail service from your phone provider, you'll need to contact your phone provider to get a distinctive ring feature. Once you'll have that feature, you can assign a distinctive ring to your printer. You can find that under Fax Setup > Ringing and Answering > Ring Pattern.
May 29, 2012 | Lexmark Interpret S405 Wireless All-in-One...
No dial tone. Cannot call/recieve.
Have you tried placing the handsets in the base unit to resync them? (not the axillary charger)
Have you confirmed that the phone jack and wire are still working? (e.g. plug in a known-good corded phone and make sure the signal is still good)
Post back with the "Add comment" button on the right, and we'll see what we can do to get it fixed.
Jan 20, 2010 | Uniden 5.8GHz Cordless Phone
When recieving call, we have no ring tone osunds
i asume that your reffering to a cell phone you should check your sound settings making sure that its setup to ring when recaiving a call if you do this make sure that you are saving your settings if this fails it could be a faulty speaker and i would take it back to where i got it good luck!
Dec 18, 2009 | Lands Phones
My phone will not dial a call. I get a dial tone,but it won't work. I also can not get it to ring the different ring tones or do the hands free speaker phone.
You have got to be kidding. I pay $25.00 for a phone that does not work and you have the ordasity to tell me that if I pay you an additional $9.95 you will e-mail me with a possible solution to my problem. If I do not here from you within 24 hours, I am going to report this to the Better Business Bureau and my local Consumer Advocate News station!
Mar 02, 2008 | Innovage LCD Touch Panel Phone
Doro Home cordless phone not working
it sounds like you may not have any dial tone in the house. some phones have a light come on when the phone isn't recieving dial tone.[in your case the anntena] you can try plugging a corded phone into different jacks in the house.there maybe a box [called a nid] on the outside or in the basement/garage where you can plug a phone directly into it bypassing all the jacks in the house [there could be a problem in the house] if still no dial tone ,call your phone company
wg
Jan 30, 2008 | Doro 530 Twin Cordless Phone
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
Nov 30, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Philips ID9370B/37 Phone Logo
196 people viewed this question
Top Philips Lands Phones Experts
Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
