Question about Siemens A65
Problem on entering a number into the phone book
Foreign numbers: No problem if the country is in the prepared country list.
But if it's not? How do I get +53 for Cuba? Entering 0053 is obviously not the same, is it? I cannot enter the + in this mode.
  • 3 Answers
Is this the A65?
If so, press and hold a 0 to get a + when entering a number
Posted on Jun 13, 2008
+000 wat is that country code
There is no country code with +000.If you have received a call from this code, this is a private call.This means that the caller do have a service where his number is not reflecting on your cellphone.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 04, 2011 | Nokia C101 Cell Phone
Tip
How to Unlock Cellular Phones for Free
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Unlocking your phone free contains simple steps which are as follows:
  • Download Nokia Free Unlock Codes Calculator to the computer. Double-click on the downloaded file to install the program.
  • Double-click on the installed program. A window should pop up with several options. Choose the make of your phone from the list given. Choose the model number.
  • Press *#06# on your cell phone. Press "OK". A number should be displayed on screen. This is the serial number of your phone, also known as an IMEI number. Enter this number in the IMEI field in the Nokia Free Unlock Codes Calculator window.
  • Select your country from the list in the "Country" field. Select the name of your cell phone network from the list given. Press "CALCULATE". A list of unlock codes should be displayed in the window.
  • Replace the SIM in the locked phone with the one that will not work. Turn on your phone. A message indicating "Invalid SIM" should be displayed. Enter one of the unlock codes and press "OK". Your cell phone should be unlocked by now.
Goodluck :)
on Dec 12, 2009 | Cell Phones
How to add new contact to phone book
There are several ways to enter a number into your Phone Book:
1. Call GreatCall Customer Service for assistance 24 hours a day, 7 days a week at 1-800-733-6632.
2. Create an account at mygreatcall.com and modify your Phone Book online.
3. Manually enter a number into your phone.
To manually enter a number, it depends somewhat on what model phone you have - either the Jitterbug Original/One Touch or the Jitterbug J. In all cases, you will need to open the phone and access the Phone Book menu option. With an Original or One Touch, this can be done by pressing NO until you see PHONE BOOK listed at the top of the screen. With a J, you will press YES once the option for PHONE BOOK is highlighted in the center of the screen.
Press the up arrow and you will see the option EDIT PHONE BOOK. Press YES to select. Press YES again to select Add. Now you will be prompted to type in the name of the contact using the Triple-Tap method. Each number corresponds to 3 letters. Tap the appropriate number in quick succession until you see the letter you want to enter. Use the "#" to enter a space.
Example: To enter the name "John," you would press 5-666-44-66.
Once you are satisfied with the name, press YES to select DONE. You will then be prompted to enter the number. It is recommended that you include 1, the area code, and then the 7-digit number even if it is a local number.
Example: 1-760-555-4321
Once done, press YES again. You will see the message Successfully Added and you are done!
Jun 17, 2011 | One Touch Jitterbug One-Touch Cellular...
How do you add to existing contact list
Jan 04, 2011 | One Touch Jitterbug One-Touch Cellular...
I wish to add new contacts and delete obsolete one. Help!
Dec 18, 2010 | One Touch Jitterbug One-Touch Cellular...
How do i add phone numbers
Oct 21, 2010 | One Touch Jitterbug One-Touch Cellular...
I want to enter a + sign before my numbers in my phone book but don't know how. I will be traveling and Rogers says I should add the + sign to all my numbers in my phone book. I also need to call a...
You don't need to dial that + symbol. It's sometimes included when writing out a number to show that you're dialing extra digits, such as a country code, along with the phone number. All you'll need to do is enter the phone number like you normally do. Just add the area code or country code at the beginning as required.
Oct 01, 2010 | Cell Phones
How do you get a new # on the phone and onto the screen?
Sep 17, 2010 | One Touch Jitterbug One-Touch Cellular...
Unlocking mobile phone for free
· Download Nokia Free Unlock Codes Calculator to the computer. Double-click on the downloaded file to install the program.
· Double-click on the installed program. A window should pop up with several options. Choose the make of your phone from the list given. Choose the model number.
· Press *#06# on your cell phone. Press "OK". A number should be displayed on screen. This is the serial number of your phone, also known as an IMEI number. Enter this number in the IMEI field in the Nokia Free Unlock Codes Calculator window.
· Select your country from the list in the "Country" field. Select the name of your cell phone network from the list given. Press "CALCULATE". A list of unlock codes should be displayed in the window.
· Replace the SIM in the locked phone with the one that will not work. Turn on your phone. A message indicating "Invalid SIM" should be displayed. Enter one of the unlock codes and press "OK". Your cell phone should be unlocked by now.
Goodluck :)
Nov 03, 2009 | Samsung SGH-a737 Cellular Phone
Ka08 sms message settings
Hello, I had the same problem, but i figured out how to get the callers id/information. On the main page select Call Center>>Call History>> SIM1(or whichever you are using)>> and select either the Missed/Dialed/Received calls. Lets choose Dialed Calls for now. Select a phone number that you recognize>>select OK>>Options>>Save to Phonebook. In here you will create a new contact. Make sure you delete this old contact information from your phone book. (so you don't have doubles if already saved to your contact list). Now you can go to your main menu again and select the phone book option. Select the contact you have created and add a photo and ring tone you like. Now when you get a call you get their photo and rign tone. For sms you get only their name, but thats good enough for me.
Jun 26, 2009 | Apple iPhone 3G
Cell Phones Logo
271 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Yoav Shilon
Yoav Shilon
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
