How to use pointer in array
Give me answer how to use pointer in array
benifit of the pointer in c language
  • 85 Answers
Array name starts with * (to makeitpointer object)
Posted on Mar 22, 2008
How do I change the language setting fom French to English
did it have a list of languages that you could chose from . you have to click pointer to english and hit enter
Jun 02, 2015 | Computers & Internet
Write a program c that declares an array of 100 elements to hold these values. Read the values in from the file and store them in successive elements of the array. Keep track of how many numbers are read...
That appears to be an intermediate question in a programming class. Best read the book, the answer is not what is important the process of getting the answer is what you are trying to learn.
May 17, 2017 | Office Equipment & Supplies
When I type Shift + @, my new Acer computer give me " and vice versa. How may I alter this?
This is probably a different keyboard layout that you used to know.
  1. Click Start , type intl.cpl in the Start Search box, and then press ENTER.
  2. On the Keyboards and Language tab, click Change keyboards.
  3. Click Add.
  4. Expand the language that you want. For example, English (United States).
  5. Expand Keyboard list, select the United States-International check box, and then click OK.
  6. In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
  7. In the Regional and Language Options dialog box, click OK.
    Notice that the Language bar appears on the taskbar. When you position the mouse pointer over it, a ToolTip appears that describes the active keyboard layout
  8. Click the Language bar, and then click United States-International on the shortcut menu that appears.
    The United States-International keyboard layout is selected.
For more help check here
May 22, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Define a character array and use strcpy() to copy a string into it. Print the string out by using a loop with a pointer to print out one character at a time. Initialize the pointer to the first element and...
Nice, computer science homework.
int main () { char str[]="this is my string";
//print our string forwards int i = 0; while(str[i]!="\0") { putchar( str[i] ); i++; }
//newline putchar('\n');
//print our string backwards int length = strlen(str); while(length--) { putchar( str[length] ); } }
I didn't test this to make sure it worked, but this is the general way of doing this. It looks like your professor wants you to use pointers. I used pointers here. Do you know how? Arrays are pointers with some syntactic sugar.
I wouldn't rely on sites like this to get answers to your homework. Even if you get the right answer, there's always the possibility of your CS professor finding this answer online and then making your future homework ten times harder.
Mar 01, 2011 | Computers & Internet
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
I don?t understand the use of pointers in C++
Pointers are variables which store memory address of other variables.
It is denoted by an astrix *
Pointers and normal variables must have same data types.
Need of Pointers:
As said pointers variables store memory addresses of other variables, this can be used when we want to perform some calculations on a variable, we pass the address of this variable to the function from using pointers, thus any changes made to the variable will directly affect the variable as it is pointed to the same memory location.
It can also be for pointing various memory locations e.g. video memory. In the days of Dos we could actually read and write directly on to the video memory using address 0xB8000000 hexa decimal address.
Declaring a pointer:
int a = 10;
int *p = &a;
Here are passing address of a to p. Make sure that the data types should be same.
When we use pointers as arrays, it is much faster then the usual array iterators.
int num[] = {43,52,54,53};
int i=0, *j;
j=&num[0];
while(i<=3) { cout<<"num ["<<i<<"] = "<<*j<<endl; j++; } // This peice of code is faster than following method
for (int i=0;i<=3;++) { cout<<"num ["<<i<<"] = "<<num[i]<<endl; }
As we are directly working on memory.
Pointers are most commonly used to allocate memory dynamically, using new operator.
int *p = new [10];
This code allocates for 10 integer type array dynamically.
Dont forget to release the reserved memory using new operator by delete operator.
delete []p; // Frees the reserved memory.
This is an overview of pointers, as it requires study and practice.
Please rate. Thanks :)
May 09, 2010 | Computers & Internet
Cant get past language selection
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
milonkoli4
Dec 26, 2009 | Nintendo Wii Console
In my keybord the punctuation are changed ...my computer come from portugal..and now i have just download the windows 7 in english version.. now the problem is the punctuation of my keybord like ? - , . [...
You need to add the English keyboard.
Follow these instructions:
  • Windows 7 or Windows Vista
    1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, type intl.cpl in the Start Search box, and then press ENTER.
    3. Click Add.
      Notice that the Language bar appears on the taskbar. When you position the mouse pointer over it, a ToolTip appears that describes the active keyboard layout.
ASpecialty4You.com
Dec 20, 2009 | Acer Extensa 5630-4933 Notebook
What problems come in project of library management
stack mismatch, over flow, memory dispatch, dynamic array alloaction, pointer conversion, type mismatch are some of the problem u experience in all projects
Oct 27, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Please Solve this C++ Program
Write a program to prompt the user to input several lines of input. A line of inputs is terminated by '*'. For each readline of input the program should output:(use pointer notation for the array) . The total # of words . The lenght of the longest word in the line At the end the program should output: . The total number of words read in all lines of input . The lenght of the longest word read in all lines of input
Jan 19, 2009 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
David Payne
David Payne
