Freeview Box :(
I have technika freeview box and recently when i try to watch tv through it it keeps flicking between the AV channel and channel 48 on my T'V. There's only one or two channels that work (i.e it will stay on the channel rather than flicking between it and another). However, the channels that do work seem to be random as sometimes i can watch a whole programme but other times it will start changing channel mid way through. Any suggestions??
  • Theazinha Mar 18, 2008
    Hum.. don't have any energy saving lamps in my house. Could be it anything else?
    Scholar:
  • 105 Answers
This kind of interference can often be caused by remote pick up from energy saving lamps.
Posted on Mar 17, 2008
SOURCE:
Technika tv help line
check the settings in the tv setup menu, the AV ports can usually be configured for analogue or digital,
Dec 07, 2013 | Televison & Video
Tv is 4 years old yesterday it lost its built in freeview channels. when trying to get the menu up it appears for a second then goes off. Tv still receives sky and picture is good
Hello pip_o
It's possibly a defective digital tuner, but the vanishing menu suggests a more serious (and expensive) fault with the main/AV board, assuming it's an LCD TV. It's impossible to be certain which one without doing some testing, but due to the inherent dangers with high-voltage electronics, I don't advise on self-repair for TVs.
If you're looking for an inexpensive solution and the TV is no longer covered by any warranty, I'd suggest buying an external Freeview box to connect to your TV. This would also enable you to upgrade to Freeview HD. Being 4 years old, your TV will not have been fitted with a DVB-T2 (Freeview HD) tuner.
If you want to try this solution, I can recommend the following box, which is great value at just £25.
http://www.ebay.co.uk/itm/270828771661
They are described as "reconditioned", but I've bought and installed 2 of these for my own customers recently and both have been brand-new. The majority of these are unused returns which Tesco are consequently not allowed to sell described as "new". For a lesser known brand, I've been quite impressed with some of the recent Technika products and they are easy to install and come supplied with all the necessary cables, etc. Additionally, if it doesn't work for any reason, you will be able to return it under UK Distance Selling regulations.
Before purchasing this (or any other) Freeview HD box, please check your TV has a spare HDMI input socket as SCART cannot carry an HD signal. If you don't have a spare HDMI socket, I'd also check your TV has a spare SCART input socket or you will need to disconnect your Sky box every time you want to use the Freeview box - which brings me to my final point . . .
. . . Off the top of my head, I can't think of any Freeviews channels which aren't available on Sky, so as long as you can still use your TV for Sky, do you really need to spend any money on it?
Hope this helps. Please let me know if I can be of further assistance.
Regards,
BElectric
Oct 09, 2011 | Televison & Video
Although the Freeview box is correctly installed with my TV,when the men button is pressed the only message to appear on the TV screen is No Signal,HELP!!
Ok, if you have "No Signal" that can only mean you must be selecting the wrong INPUT, when it is hooked up yo the TV, essentially the TV, is just a Display Monitor, and it doesn't use "Channels" anymore, it uses the AV, or EXTERNAL Inputs, any channel changing is done on the Freeview box. Make sure you are connected color to color, cables are connected. The antenna, goes into the freeview, the AV cables go to TV, taking the Video 7 Audio, from the Freeview box, to the "Screen" TV, set to the External input, that the "Box" has been connected too. Check your manual out.
May 08, 2010 | Televison & Video
Freeview box
After scanning the box should save the channel automatically. If the box does not save the preset after scanning channels, then it is probably faulty.
Some box has a pinhole reset button at the back, if you have this reset button keep it pressed with a pencil for 10 seconds to reset the freeview box.
If it does not work, the nbox is probably faulty.
With freeview you only pay for few scrambled channels, the most of them are free and do not need any additional fee.
Freeview is not available in all areas, check that you have freeview in your location, and that aerial is well connected to the box, otherwise not finding channels is normal.
Sep 05, 2008 | Televison & Video
My Thompson Freeview box keeps stuttering/time lapse freezing.
Hi Ive just bought a thomson dtr box and the picture keeps freezing .new arial new cable etc.well ive just tried a £20 freeview box and its fine good clear picture and dosnt freeze.I had a good signal when using the thompson box and its the box load of rubbish taking it back to shop.
Apr 14, 2008 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Chris..
Jan 08, 2008 | Televison & Video
Televison & Video Logo
109 people viewed this question
Top Televison & Video Experts
Ekse
