Question about Dacor DMT2420 1200 Watts Microwave Oven
Dacor Microwave our microwave shoots sparks and sounds like there is sparks shhoing in the oven. the wave guide has a hole in it now where the sparks look like they burned a hole
  • Vickery Apr 29, 2008
    Waveguide cover is charred. I tried to examine the waveguide itself with a magnifying glass, and the best I can tell, there appear to be 5 or 6 pin-sized holes in the metal guide itself adjacent to where the charring occured on the waveguide cover.
    Are these holes something that can be repaired, or is the microwave useless? Or, should I get a new $5 waveguide cover and see how long it works?
    Thanks in advance,
    vickerymarine@yahoo.com
  • Anonymous Feb 12, 2009
    That same thing happened and sparks flew...I read on epinions that one person replaced the guard and it worked for a while and then sparked and burned again...another person had a repairman say that it coulsn't be fixed and the microwave was useless. A lot of reviewers say that Dacor does not stand behind their product, so I don't know who to call
  • Dacor Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
The part would be much cheaper if you get the Sharp version (these ovens are made by Sharp) instead of the Dacor branded part.
The model DMT2420 is essentially the same as model R440D / R540D.
The Sharp part number is PCOVPB085MRP0 (zero on the end) and you can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 18, 2008
There was a little explosion of sparks in my Hamilton Beach microwave, leaving a black residue on the waveguide cover and a chemical smell inside the oven. Oven still works. Is it safe to use?
not until you have it checked out in a repair shop.
using a microwave oven where it is possible that the microwave generated by the magnatron can escape to outside, means that any person in the vicinity of the unit can suffer radiation burns and /or get cancer if allowed to be exposed a simple check is all that is necessary
Mar 07, 2017 | Hamilton Beach Microwave Ovens
Microwave sparking
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. Replace with same type. If not check the waveguides within the cabin for food particles that can burn and spark, check for rust that can corrode and spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
Click on replacing waveguides: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Jan 29, 2013 | Bosch 500 HMB5050 Microwave Oven
Maytag UMC5200AAW SS # 51285923 Never had any problem until, today it sparked and a small fire out of the top of the cover on the inside top of the right wall panel. We have it built in to a cabnet...
That sounds like a wave guide cover that protects food splatter from getting into wave guide. will need to replace that cover and thoroughly clean inside of unit ans around cover. Those covers must be kept clean and dry!!!
Sep 10, 2017 | Maytag MMV5100A Microwave Oven
Sharp r-930ak microwave oven is sparking
A dirty or damaged wave guide cover can cause sparks, fire and noises. You can order a replacement wave guide cover from many appliance parts websites for less than $15 in many cases. It should fix the problem.
May 03, 2010 | Sharp R-930AK Convection/Microwave Oven
Magnetron has 2 small holes in antenna due to previous wave guide being dirty.Is the microwave still safe to use,no sparks or arcing.
Some magnetrons have holes in the antenna by design. If these are clean holes on opposite sides near the RF gasket then they belong there. If the holes are obviously burn damage but don't cause any improper operation, the oven is safe to use.
Apr 10, 2010 | Sharp R-820B Convection/Microwave Oven
The top plate inside the microwave sparks while cooking. We checked the dish we were cooking with, the papertowel that covered the dish. What could be causing this?
The wave guide could be dirty or damaged. Dirty oven interior can also cause sparking. The wave guide is probably not dirty if it's not on the interior of the oven . Some are behind the interior wall .
Mar 28, 2010 | Whirlpool MH7140XF Microwave Oven
Arcing inside and there is now a small hole on the panel side. Is this fixable?
It looks like there's lightning (arcing) inside my microwave When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
  • If the wave guide has any burn spots, replace it and clean the unit well.
  • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
Thanks for contacting Fixya
Jun 20, 2009 | Microwave Ovens
My high power GE Advantium microwave is sparking
Your problem is a common one. When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
May 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Magnetron antena metal cap hole due to spark
it is not safe to use this, DO NOT USE, repalace immediately, no need to repaint
Mar 22, 2009 | Sharp R-820B Convection/Microwave Oven
Popping and shooting sparks
Hi There!
Check behind the "Wave Guide Cover" on the inside cavity. There may be moisture or food residue behind it. Should be a cover that is plastic or Mica. Really strange that it's sparking being new. Also check that you use plates without gold or silver trimmings (Crockery or porcelein). This will also cause sparking. Remember that microwaves will always go to the first organic source in its path. The wave guide cover, if soiled, is very close to the tip of the Magnetron and will therefor result in arcing. Good Luck, JUS004
Feb 26, 2008 | Frigidaire PLMV169DC Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
656 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
