Question about EPoX EP-8KHA+ Motherboard
Connecting to -5V
I had to change the ATX 20-pin contact on my EP-8KHA motherboard, but I'm afraid I managed to damage one of the connecting points. As far as I can tell, the -5V is not connected to the circuits on the board any longer. Could someone please guide me to another point that is electrically the same as where the -5V pin of the 20-pin contact should be connected? (Then I can connect the -5V pin to that point using a cable.)
  • MickeP Mar 19, 2008
    The help I need has to be from someone who knows the specific board.
    The solution suggested is not viable since it's a multi-layer circuit board, and the connection to that specific pin is not visible.
    So, once again:
    Does anyone know (and like to share it with me) of any other point on the motherboard EP-8KHA that is equivalent to the point where the -5V pin should be connected?
  • 807 Answers
You will just have to follow the track from pin 18 on the connector to the next solderable point on the board.
Posted on Mar 19, 2008
Can I tap a -5v into a BESTEC atx-250-12z-rev d2 power supply ?
The output from the power supply is
Output Max. Load +5Vsb 2A -12V 0.3A +12V 13A +5V 30A -5V 0.3A +3.3V 20A Pin 18 out of 20 white -5 volts (optional)
20 out of 24 white -5 volts (optional) See the definitive connector definition.
All about the various PC power supply cables and connectors
Mar 05, 2015 | Computers & Internet
Standby 5V overvoltage (8-9 volts instead of 5): what's probably damaged?
  • Check the voltage on the Power supply. (5V STB is on pin no. 9).
  • Check the voltage (on pin no. 9) from the back of the motherboard on ATX socket.
  • Check the voltages on the Front Panel connector for 3.3v, 5v and ground.
  • Check for shorting by placing one probe of multimeter on the ground and the other one by one in pin no. 1,2, 4, 6, 8,9,10,11,12,14,19,20 also on the CPU connector. If there is shorting the problem is with some component on the motherboard.
I think probably the Power Supply (SMPS) is faulty.
Hope that helps.
Oct 23, 2013 | Intel D925XECV2 Motherboard
ATX motherboard connector pin out
Black=0V(GND)
Yellow=12V
Red=5V
Orange=3.3V
Purple=5Vsb(everytime on)
Gray is PWRGOOD or PWROK(pwr=power) must be at 5v
White=-5V(optional)
Blue=-12V
Green is PWRon must be connected to a black wire to turn on the PSU
Nov 16, 2012 | Enhance Technology ATX-1123B, Enhance...
What is the watt for a power supply for a compaq presario sr2020nx. the computer will not turn on. i checked all other possible power sources.
Looks like it comes with a 550w power supply, so anything in that range would be fine. Below are the specifics if you need them.
Best of luck, William
-------- " Replacement power supply for Compaq Presario SR2020NX- 550 Watt Replacement Power Supply Upgrade
- One (1) 20+4 ATX Power Connection
- Two (2) SATA Connections
- Four (4) large molex connector (4-pin)
- One (1) One (1) floppy connector (4-pin)
- One (1) ATX 12V connector (4-pin)
- One (1) 6-pin PCI-Express Connection (6-pin)
- ATX Form Factor
- 575 Watt Replacement Power Supply
- Input Voltage: 100 - 240 Volts AC
- Width: 5.75"; Height: 3.25"; Depth: 6.0"
- Voltage: +3.3V (38A); +5V (40A); +12V (25A); -5V (0.5A); -12V (0.8A); +5V (2A)
SATA Support
- Supports both 20 and 24 pin motherboard. Great Power Supply Replacement or Upgrade. Compaq PSU Presario SR2020NX Power Supply Replacement"
Mar 03, 2011 | HP Compaq Presario SR2020NX PC Desktop
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
Nov 18, 2008 | Pc Ware M748LMRT Motherboard
Front panel usb
Step 1: Decide weither you have one or two USB cables joined together, it should look like a 4 PIN header.
Step 2: Get your manual from ECS: http://www.ecs.com.tw/ECSWorldWide/Index.aspx?MenuID=0&LanID=9
Step 3: Install the 4 PIN header the right way +5V, - DATA, + DATA, GND on the motherboard, refer to the manual if you get stuck.
Oct 26, 2008 | EliteGroup ECS P4M800-M Socket...
Power supply
ATX Version 1.2 - 20 wire motherboard connector Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 Pin 10 3.3V 3.3V Gnd 5V Gnd 5V Gnd P_OK 5VSB 12V Oran Oran Blk Red Blk Red Blk Gray Purp Yell Oran Blue Blk Green Blk Blk Blk White Red Red 3.3V -12V Gnd P_ON Gnd Gnd Gnd -5V 5V 5V Pin 11 Pin 12 Pin 13 Pin 14 Pin 15 Pin 16 Pin 17 Pin 18 Pin 19 Pin 20 The color scheme used for the voltages in the 20 pin connector holds for the other ATX standard power supply connectors. However, brand name manufacturers often build proprietary power supplies or make up their own color coding, so I wouldn't throw out a power supply that supplies 5V where you think it should supply 3.3V. It's more likely a proprietary design than a failure.
Feb 21, 2008 | Computers & Internet
Motherboard not functioning
If the power supply had a problem then it is likely that the motherboard and/or the CPU got damage from that. I would check the 12V and the 3.3V lines from the PSU.
Without more information I cannot say specifically what the problem is. You can try disconnecting everything from the motherboard except video card, CPU, and RAM to see if it would work that way. If it does then you can start connecting devices until it does not work any more then you have found the problem. If that does not work at all then unplug the video card and RAM see if anything changes (you should get a beep code without the video or RAM). If nothing changes then either the CPU or motherboard is bad and the only way that I know of to find out which one is to either try the CPU in another motherboard or try a different CPU in that motherboard.
Nov 12, 2007 | Intel Motherboard
EPoX EP-8KHA+ Motherboard Logo
66 people viewed this question
Top EPoX Computers & Internet Experts
David
David
Alun Cox
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
