Question about Epson Stylus C40SX InkJet Printer
Renew ink how do i change ink cartridges on epson 4400
  • 353 Answers
A comprehensive guide to ink cartridge replacement is given in the on-line manual at:
http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
If you need further help, please post a new comment.
Posted on Mar 08, 2009
I have a epson stylus 480 printer which is not been used for years,my question is now I have to change the ribbon or just fill up the ink cartiges or what? and how to connect it with a laptop, do we...
The inkjet printer has ink cartridges, not ribbon.
Cleaning Jets:
After so long, the cartridge jets are probably dried out and blocked.
You will need:
Boiling hot water,
Shallow dish.
Paper towel,
Like this:
Open lid.
Unclip each cartridge and soak bottom copper part "jets" in hot water until you see ink flow freely.
Gently wipe its bottom with paper towel, then pat dry.
Empty and renew water between colors.
Clip back in same place (color cradle) that it came from.
Otherwise renew with same part number.
Connector cable:
Use a cellphone or other camera to photograph the printer connector and laptop connector.
Show the photos to your computer dealer to match data cable and power cable.
Printer hardware Driver:
Some versions of Windows will recognize a printer as generic.
If you're lucky, it may have your model already listed.
Otherwise for full function,you need to download and install a hardware driver for this printer.
Dec 18, 2017 | Epson Stylus Color 480 InkJet Printer
My printer epson dx 4400 dont recognise black...
Remove the cartridge and check the contacts after taking it out. Now reset the cartridge back to the holder and remove printer. Now un-install the printer drivers from the PC, then reinstall and connect printer to be detected and installed. If the cartridge is not seen now there are errors in the mother board or the ink cartridge holders.
Feb 07, 2011 | Epson Stylus DX4200 All-In-One InkJet...
I can't change my black cartridge in my epson dx 4400 what do i wrong because he doesn't stop in the place where i can change the cartridges
HI, You have to be fast in changing the cartridge in Epson printers. The instructions are usually printed in figures. try to follow it carefully.
Cheers!!!
Aug 31, 2010 | Epson Office Equipment & Supplies
I would like to refill Epson Stylus CX9400 old ink
You cant recode the cartridge it is programmed to die and fry. You can get chips but many DIY filling options are going to cause you other issues down the road, they are a cheap way to run your printer but eventually willc ause you issues such as ink leaks which leads to the in pad needing to be renewed not to mention some other horror stories. I would alays reccomend OEM inks, but if non OEM is hte way you want to go contact a retail outlet that specialises in refilling spent cartridges.
May 11, 2010 | Epson Stylus CX9400 Photo Printer
Installed ink. Lights still flashing
its common issue with epson, please turn off, and remove all the cartridges,power it on again without them, better still use the site to get the user manual
http://safemanuals.com/annexe_PRODUCT%20DOCUMENTATION_EPSON_STYLUS%20PRO%204400-_E.htm
Mar 13, 2010 | Office Equipment & Supplies
I have an Epson Stylus 4400. when I replaced the ink cartridge with a new Tesco cartridge it still registers empty.
Compatibility issues. The epson cartridge has an intellidge chip so the printer's sensor can read the cartridge properly.
Try to take the cartridge out then put it back in to the printer. Let it charge like it normally does.
Use an epson cartridge. Log on to epson.com to get the compatible cartridge for your printer.
Apr 29, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson stylus dx 7450 printer
You have a wide format printer but it has the same basic principle as the desktops. You can buy remanufactured cartridges which were reset for you. Or you can refill them. If you refill them, you need a resetter because Epson cartridges have a chip on them which needs to be reset. Because when they are empty, the printer will recognize it as empty and will not function till you put in a new cartridge. If you bought a remanufactured cartridge, and your printer won't recognize it, you need to go back to who sold you the cartridge and either have them reset it or give you a replacement.
Jun 19, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus photo 2100
Highly possible that the "compatable" cartridges are not really compatable or that Epson has updated software or firmware to keep them from working. Try replacing with Epson cartridges or see if the non-OEM brand seller has a resetting device so the printer sees those cartridges as full.
Dec 06, 2007 | Epson Stylus Photo 2100 InkJet Printer
Epson Stylus C40SX InkJet Printer Logo
142 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
