Question about Video Game Consoles & Games
Put disk in says E68 - Video Game Consoles & Games
  • JOPPERS Mar 17, 2008
    got at christmas..xbox 360 halo green edition
  • 19,396 Answers
Which make and model is your console?
Posted on Mar 17, 2008
  • Ginko
    Ginko Mar 17, 2008
    If you do not know the model check model number at the back.
  • Ginko
    Ginko Mar 18, 2008
    This error code appears in the center of a black screen on the
    television or on the monitor.
    If you receive a different error message, you are experiencing a
    different issue. For more information about what to do if one red light
    flashes and you receive a different error message, click the following
    article number to view the article in the Microsoft Knowledge Base:
    907536 http://support.microsoft.com/kb/907536/)
    Comment by ginko, posted on Mar 17, 2008This behavior occurs when an Xbox 360 Hard Drive hardware failure occurs
    THINGS TO TRY
    l
    1.
    Turn off the console.
    2.
    Remove the hard drive. For more information about how to attach or
    remove the Xbox 360 Hard Drive, click the following article number to
    906204 http://support.microsoft.com/kb/906204/)
    Xbox 360: How to attach or remove the Xbox 360 Hard Drive
    3.
    Reattach the hard drive, and then turn on the console. If the problem persists, discuss replacement options with the agent.
    4.
    Obtain the latest automatic update for the Xbox 360. To do this, connect to Xbox Live.
    5.
    If you continue to experience this behavior, contact Xbox Customer Service.
    If the agent cannot help you resolve
    this issue, you must replace the hard drive.
    Many thanks for rating
    President:
  • 1,944 Answers
Which video console are you talking about?
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Aug 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
When i turn on my xbox 360 system error E68 comes up
This problem seems related to the hard disk drive, try putting it off the console an on again and see if it works!
Maybe the driver has displaced a little bit!
Hope this helps!
Mar 05, 2011 | Microsoft Video Game Consoles & Games
I have a e68 on my xbox 360 what can i do to fix it
e68 is an easy fix, one that shouldn't even be charged for.
ok, so let me tell how it's going to work, the E68 means that your HDD needs to be updated,
so you have to get to http://www.xbox.com/en-US/support/system… ,
and then download the update file, and uncompress it ,
then rip it on a disc or a DVD,
then just set your 360 to Boot to disc from System----> console Settings------> Startup
then put the disc in the 360 , then turn it off,
and attach the Hard Drive
then turn it back on and the 360 will apply the update to the Hard Drive,
and if it didn't work your Hard drive may need to be replaced.
Jan 17, 2010 | Microsoft Xbox 360 Console
E68 error on xbox 360 HELP PLEASE
A Working Solution.
Remove any disk from the DVD drive.
Remove the hard drive and turn on. When you get to the dashboard turn it off again by holding the X button on the controller and select 'Turn off console'.
Wait 10 seconds and then turn on again by pushing the X button on the controller. When you get to the dashboard turn off again via the X button.
Remove the AV / Video plug from the back of your Xbox.
Replace the hard drive correctly.
Switch on the Xbox via the power button on the console. 4 red lights should flash.
Wait 10 seconds and re-insert the AV / Video cable.
You should now load into the dashboard with your hard drive profiles - wait theres more!
Turn off and on via the X button as before another 2 times with all leads and the hard drive in place.
After you power it off the second time, remove the power lead for 20 minutes and then turn on again any way you feel like it and it should be cured.
Aug 06, 2009 | Microsoft Xbox 360 Console
Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
shaun
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Xbox 360freezes up
E68 = Turn off system, take hard drive off, put hard drive back on, turn system back on.
I don't know about E79
Dec 22, 2008 | Microsoft Xbox 360 Console
Hi, I am getting an error E68 on my dryer
Hi have you tried putting less into the machine as this could be a simple over weight problem
Oct 27, 2008 | Frigidaire GLEQ2152ES Electric Dryer
XBOX READING E68
This error code appears in the center of a black screen on the television or on the monitor. If you receive a different error message, you are experiencing a different issue. For more information about what to do if one red light flashes and you receive a different error message, click the following article number to view the article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/)
Mar 17, 2008 | Video Game Consoles & Games
E68 error
E68: Hard Drive Error
Sorry to say you got a bad hard  drive. Call MS or take the system back to walmart for a new 1 because I dont think they will give you a new hard drive. Who knows they might, call and ask!
Oct 12, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
