Question about Mag Innovision LT765b 17" Flat Panel LCD Monitor
Picture goes black on Mag Innovision LT765b
I have a dual monitor setup, and the MAG just started going black. It comes up just fine, but after a few minutes, the picture just ends. My PC still thinks the monitor is connected, and the display on the other screen is unaffected...even the power on light doesn't change. I've checked all of the connections, and even tried re-connecting the video cable, but the only thing that brings the picture back is a power cycle (after which the image is fine again for a few minutes). I'm afraid it's just done, but wanted to see if there were any other suggestions first.
Thanks in advance for the help.
  • Anonymous Nov 26, 2008
    same problem- picture goes black after a few minutes
    Novelist:
  • 138 Answers
I used to repair LCD monitor from Dell. It works for me. You might be using these following steps to examine what wrong with your monitor. After you turned PC on and monitor stopped working or went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image (Start menu), there will be a minor problem. This is because of CCFL lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you.
Posted on Mar 18, 2008
3 Suggested Answers
6ya staff
SOURCE:
mukund_ce
Mukund Ubhadiya
  • 186 Answers
SOURCE: i need driver monitor mag innovision for install
Chek Ur OS and download drivers from here :
http://list.driverguide.com/list/company621/
Posted on May 16, 2009
Anonymous
  • 34 Answers
SOURCE: need power cord for mag innovision LT765b
if you have the old one, radio shack may have a compatible unit. Other than buying it from the manufacturer you can get them from ebay pretty cheaply.
Posted on Jun 14, 2009
PL 9 19" CRT Monitor: my mag innovision lt716s 700p monitor screen keeps...
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 06, 2010 | CTX PL 9 19" CRT Monitor
Screen goes black after a few seconds.
when the screen goes black shine a flashlight on it. If you see a dim image the back light needs to be replaced. Otherwise check the inverter as that may be causing the problem as well.
Sep 07, 2009 | Mag Innovision LT782S 17" Flat Panel LCD...
Need power cord for mag innovision LT765b
Jun 14, 2009 | Mag Innovision LT765b 17" Flat Panel LCD...
MONITOR MAG LT916S
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 12, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MAG Innovision LT1919WDb flat screen goes black
I had the same problem. I contact the manufactuer and they refused to fix it. They said it would cost an additional $100 to have it fixed. I have not even had it a year. I thought products sold in America were suppose to last longer than a year? What has happened to companies standing behind there products. Beware of this monitor!!! DO NOT BUY IT!!! LT1919WDB
Jan 30, 2008 | Computers & Internet
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Wont power on
hi , please change the signal cable which is connected from CPU to monitor. please rate this comment.
Sep 15, 2007 | Mag Innovision LT765b 17" Flat Panel LCD...
My MAG Innovision Monitor went blank, only works if I stay connected to internet
usually this problem is caused by a faulty inverter circuit. transistors might been running too hot or a leaky capacitors also.not an easy task but try looking down for any defects on high voltage sections.
Feb 24, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision LT765b 17 in. Flat Panel LCD Monitor
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Aug 30, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
Open Questions:
See all Mag Innovision LT765b 17" Flat Panel LCD Monitor Questions
Mag Innovision LT765b 17" Flat Panel LCD Monitor Logo
184 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Thomas F. Schneider
Damen Wong
Damen Wong
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
