Question about Samsung SyncMaster 765 MB (Black) 17 in.CRT Conventional Monitor
Strange picture I have a SyncMaster 765 MB. This monitor have three Magicbright modes. Normal, internet, and film. At tha last two modes the windows icons semms like it had "tails" I mean there is no discrete end of icons instead a little darker but not blury instead sharpy continouing. And this strange thing totally dissapears at normal mode. I reduced the contrast and the brighness at the higher bright mode but there was no change. May the Magicbright circuit went wrong? Pls, pls help sdy Thx
  • 277 Answers
SOURCE: Monitor dark only when display PC, normal TV
hi have you checked your PC output? check it with another screen (whichever) and see if the output signal is good if soo check the cable and connections to your LCD check your PC for software configuraitions: 1) TV output 2) good resoulotion 3) media borad is strong enough to handle this LCD if all is good then maybe the TV borad is sending a low voltage/current then the LCD can see good luck
Posted on May 08, 2006
  • 5 Answers
SOURCE: samsung syncmaster 740n monitor problem
Add a 50 ohm between pin 5 and 6 of the NT68F63LG IC.
Go to this link to learn the details. http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&sa=X&oi=translate&resnum=3&ct=result&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
I tried this fix on my monitor and it works now.
Posted on Aug 28, 2008
SOURCE: Problem with Samsung SyncMaster 226BW
Click the top button on the side of the monitor to open the monitor's settings. In the "Picture" Settings, scroll down to "MagicBright" and open those settings. Chances are you have it set to "Dynamic Contrast". Switch that up to any of the other settings and then it won't try to adjust the gamma based on what is on the screen.
Hope this helps, I struggled with the same problem for quite a while until I found this setting.
Posted on Jun 12, 2009
  • 732 Answers
SOURCE: dark screen samsung syncmaster 920 N strange noise behind it
calin_vedina, Please use Samsung warranty first!!! If unit is still covered by warranty. Also read my response to another 920NW owner (rfusco187) on 12/17 click on BLUE text "SyncMaster 920NW Monitor" above. If this response useful to you, please come back and rate it on fixya. 12fixlouie
Posted on Dec 19, 2009
  • 1684 Answers
SOURCE: Backlight going bad?
This is not the backlight its the power supply board. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ The repair consists of replacing 5 capacitors on the power supply board. If you can solder then you can do this repair. If you don't want to do the repair we do offer a repair service, you can get this information here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Apr 28, 2010
Testimonial: "I know this has been quite some time ago, lol. I did since replace the capacitors and still had an issue. There was another component that went bad (can't remember what) which was too expensive to replace given the price reductions on newer bigger monitors. Thanks for your help!"
How to stop MagicBright
You cannot exactly stop it but you can configure it. See the link I included for the complete instructions and screenshots.
You probably have it on Dynamic settings as it would change constantly. I would suggest to keep it under "Standard" or "Custom" if you like your own setting to be permanent.
Configuring SAMSUNG MAGIC Bright Samsung Support Singapore
Feb 20, 2018 | Samsung Computers & Internet
I want to remove MagicBright from my screen, it is blocking bottom left of screen and has been for days, I want it out of the system, I don't know how it got into the computer.
unplug then open the case then remove the little white plug from rear of switches job done no power light or buttons but picture is fine ; )
Jul 19, 2011 | Samsung SyncMaster 720N Monitor
Our samsung syncmaster 2493hm fades to black when on websites with dark color backgrounds. How Come? Is there a fix?
Its probibly the MagicBright settings, press the button next to the menu button (its down arrow) and change the settings to something else, i changed mine from "Dynamic Contrast" to "Game" and everything is as they should be now.
Jul 13, 2011 | Samsung SyncMaster 2493HM Monitor
Magicbright keeps flashing on. how do i disable it
Solution: Unplug your monitor for a couple minutes, plug it in and magic, it is fixed.
Jan 05, 2011 | Samsung SyncMaster 720N Monitor
I have samsung syncmaster 933 monitor. It keeps blinking on and off. We have rebooted, unplugged and replugged all connects from pc to monitor and still it keeps blinking on and off. Not able to...
It may have unstable DC voltages due to failing DC filter caps which is very common problem to all LCD monitors as shown in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 20, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Feb 19, 2009 | Samsung 226BW Monitor
Graphics card problem
hi......
all u need to do is to set up the screen refresh rate to default and always keep ur graphics drivers up to date
Nov 16, 2008 | Nvidia GeForce4 MX 440, (64 MB) Graphic...
Samsung SyncMaster 193V magicbright
hold the menu button down until the menu disapears again
Mar 11, 2007 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Samsung SyncMaster 765 MB (Black) 17 in.CRT Conventional Monitor Logo
53 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
ismael castillo
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
