Fisher and Paykel Pride MW059 Washing Machine won't drain
As my freshly washed clothes had sandy grit all over them I went to put them back with the next load I had started washing. The machine was very full, and washed the items, but started continous beeping when it came to the rinse cycle, and the last 2 or 3 lights where on. I tried reprogramming it, and taking some clothes out, but to no avail. No more alarms, just a humming noise like it is trying to drain. I manually emptied it and dismantled it as much as could/game and the drain pump does not appear to be blocked as I can move it, and can blow air up the pipe. Please share with me any suggestions you may have to solve my problem. Thanks
  • Bubbles0000 Mar 19, 2008
    Thanks for your help- it wasn't sand in the pump but a sockette!!!
    Sergeant:
  • 351 Answers
It sounds like you have sand in the pump,you can remove the bowl to get access to it,or remove the pump from underneath which is easier.but you must remove all water first.the pump is a click in fit you just bend the white plastic clip but not to far then the pump will twist out.hope this helps.
Posted on Mar 17, 2008
I am getting a lot of lint on clothing is there a cleaning process with my smart drive pride 5.5 fisher & paykel washing machine
clean the lint filter in the machine
put any clothes that are likely to shed lint or are susceptible to collecting lint in a wash bag before putting in the machine
Oct 17, 2017 | Fisher Washing Machines
Code 37 -
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
I have a Frigidaire Pride Smart Drive top loader washing machine and I would like to give the bowl and inside where the powder goes in, a jolly good clean. How do I go about this? I'm worried that...
hi i have a fridgedair pride 5.5 wen i turn my washing machine on theirs know water going into the machine the water keeps going stop go stop go how can i fix the problem every thing else is fine.
May 26, 2011 | Fisher and Paykel Washing Machines
Hi, My washing machine, Fisher and Paykel, MW 511 PRIDE would not do the SPIN cycles. Please advise. Thanks. Sam Lee
Hi Sam Lee.Now , does the machine drain the water?If it does drain the water does it stop and beep and show an error code?if it does the error code will be a series of lights that will light up when the machine is beeping.They will be on a row of 8 lights.Starting from left to right which lights are lit when the machine beeps,Is it the 2nd and 4th or the 3rd and 7th ---etc---?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 03, 2010 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Where is filter MW059
it has a Auto-lint Disposalsystem which means there is no filter to access ,,,,, if your having lint on your clothes, check to make sure the drain hose isn't kinked and no down in the drain pipe to far.
Lary
Nov 05, 2008 | Kenmore 24032\24036 Top Load Washer
Fisher and Paykel Pride 5.5kg washing machine, everything works fine until you get to the spin cycle and then it just beeps and won't do anything more. What can I do to check or fix this?
My washing machine will not cut off on a high water level, but will on the medium. It will wash until it gets to the short wash and then it just beeps at me. I tried to advance it to the rinse cycle but the light just blinks and won't do anything more. It did drain the water out though. What's the problem and how do I fix it.
Aug 05, 2008 | Washing Machines
Washing Machines Logo
575 people viewed this question
Top Washing Machines Experts
