Question about Kodak EasyShare DX4530 Digital Camera
Camera error i have error e41 on screen
  • 3 more comments
  • Anonymous Jul 03, 2008
    CAMERA HAS A ERROR #E41 HELP WHAT DO I DO?
  • Anonymous Nov 15, 2008
    camera shows Camera Error #E41. Checked batteries, they are good.
  • Anonymous Jan 11, 2009
    what can i do with "error E41?
  • dx4330 Feb 11, 2009
    I have a Kodak DX4330 Digital camera that displays camera error #41 on the viewing window. Is there a solution to fixing this problem? What does error 41 represent?
  • Anonymous Apr 07, 2009
    camera Error #E41
What exactly is error #41 on dx4530
Posted on Dec 12, 2008
6ya staff
SOURCE:
Showing on screen E41
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button simultaneously for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Sep 14, 2015 | Electrolux Washing Machines
What is error code E41
Hello Scott - If you are receiving an error code E41, your loading door may be ajar. Double-check to ensure that it is closed. If it is secure, reset the power to your appliance for about 30 seconds. You can do this by unplugging the unit or flipping your circuit breaker into the off position. If the error persists, it could either be the door switch assembly or your unit's main control board. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Jun 10, 2013 | Electrolux Ewf1090 Front Loader Belt Part...
Fridgidaire upright washer E41
Hello Marcee Peterson - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Canon G12 does not connect to USB cable, gives error E41
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Sep 23, 2012 | Canon Powershot G12 10 Megapixel-5x...
Frigidaire ATF6000FS1 Error Message E41. I set up the machine, hit the start button, and I only get he PAU note across the screen. The washer will not start up. Ran the Diagnosis and come up with E41. ...
Hello
The circut board thinks the door switch is open.Try unpluging machine for 3 min.The restart as normal.
Its more a control board issue then a door switch.
Apr 08, 2011 | Frigidaire Washing Machines
How can i charge my benq dc e41 camera through pc?
All you need it to connect the USB cable that came with the camera, hook it up to the computer.
Thank you for using Fixya and your generous rating will be much appreciated.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Oct 20, 2010 | BenQ DC E41 Digital Camera
My PowerShot SX120 IS keeps showing a e41 one
Use a card reader to download to a folder you create on your desktop.
Apr 19, 2010 | Canon PowerShot SX120 IS Digital Camera
Benq e41
plz my camera sothwear beng dc e41 hurry up plz
Mar 19, 2008 | BenQ DC E41 Digital Camera
Camera Error Message #E41
Hello Yami, I suggest you that dont leave any digital camera non-used for a long. your error shows that camera needs service. I think that you can not do it yourself. But try onething, just store your camera in a small corrugated paper box twice bigger than camera and leave it in sunlight for a couple of hour. then take it indoor and leave it for an hour to cooldown at room temperature. Now it is suggested to incert the batteries and try to operate. I hope your problem will be fixed. pls remove the battery when you leave the camera in sunlight. good luck.....
Jul 25, 2006 | Kodak EasyShare DX4530 Digital Camera
Kodak EasyShare DX4530 Digital Camera Logo
449 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
