Propane tank is half full. Reconnected gas line and made sure tank nozzle was in open position and burners were turned to hi. No gas coming through line to ignite. All gas hose connections seemed to be fine. Could there be a clog?
Thank you
Two things could be wrong. Tank valve could be bad, not allowing gas to flow. Or regulator could be bad not allowing gas to pass. Try taking the tank off and pushing a screwdriver into the end of it with the tank open, if gas doesn't come out tank valve is bad, valve has a spring in it to shut down if starts leaking. If tank valve is good regulator must be bad. I am leaning more towards to the tank valve.
