Lexmark X5470 All-In-One InkJet Printer
Problem for Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 series all-in-one fax printer scanner copier
By loake4shoes on Mar 17, 2008
I am having the sample problem as someone else on this site with my scanner. The display is reading CANNOT RETRIEVE APPLICATION LIST. I tried everything and referred to the index for help as well as the manual. The person with this problem before said she was trying to set up from the printer when she should have been setting up with the desktop, but I've tried it with both. What am I doing wrong? Please help me as soon as you can my mom died on friday and I am desperately trying to scan photos of us together for a collage.
Michelle
I have the lexmark X4550 Wireless Printer, this does the same thing cannot retreive application list when trying to scan from printer to computer via wireless. I have three PCs all Dell laptops and run Vista 64 bit business.
It does work if you after installing printer and setting up your network connection, but only once and I do it Like this: Once setup and computer and printer are booted, on pc go to internet explorer type in IP address for printer > configuration > scan to hosts > select delete all hosts > re-start pc and printer > once pc booted, boot printer > go to start on pc > all programs > Lexmark solution centre > advanced > change name of pc > press entre > and exit. Now go to Printer and select scan then select > new name on printer screen > press ok > scan to computer > start > and scans to pc. This makes it work however only once as will be seen when you try to scan again.
Now go to eventviewer on pc and see results, it will be seen an error occurs with the print spooler and the error says, cannot connect to an existing connection file is corrupt or missing.
Log Name: System
Source: Microsoft-Windows-SpoolerWin32SPL
Date: 17/03/2008 10:14:07
Event ID: 4
Task Category: None
Level: Warning
Keywords: Classic
User: N/A
Computer: MichaelNutti-PC
Description:
The print spooler failed to reopen an existing printer connection because it could not read the configuration information from the registry key S-1-5-18PrintersConnections. The print spooler could not open the registry key. This can occur if the registry key is corrupt or missing, or if the registry recently became unavailable.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-SpoolerWin32SPL" Guid="{13E8B4F7-4D1C-4F65-95A2-39C6B26A3012}" EventSourceName="Client Side Rendering Spooler" />
<EventID Qualifiers="49152">4</EventID>
<Version>0</Version>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2008-03-17T10:14:07.000Z" />
<EventRecordID>8489</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>System</Channel>
<Computer>MichaelNutti-PC</Computer>
<Security />
</System>
<EventData>
<Data Name="param1">S-1-5-18PrintersConnections</Data>
</EventData>
</Event>
I hope by shareing this info a solution will be found
Clarification Request
Posted by seeshell50 on Jul 01, 2009
I HAD a Lexmark X5470,which was REPLACED by Lexmark with a newer model X5495.I want to know if I am able to use the driver from the X5470 which I prefer (All in one solutions/center?)I still have the disc for the download for the driver for the X5470, I have downloaded the driver for this X5495 and dont like it at all,(hard to understand,cant do the things I done with the X5470 series)
Same Problem
Apr 10, 2009
-   I would like to put icon on my board as It was there before and I lost it
Lenmark 5400-   Guest
Feb 22, 2009
-   MY PROBLEM IS THAT MY COMPUTER ANNOUNCES THAT IT COULD NOT FIND DRIVER SOFTWARE FOR MY DEVICE
-   Guest
Best Solution
posted on Apr 15, 2009
Very Helpful)
jfh234
Rank: Apprentice
Rating: 100%, 2 votes
I had the same problem on my Lexmark 5400 All-in-1. By using the Camera and Scanner Wizard instead, I was able to scan.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jan 12, 2009
Not Rated)
laurenkyle
Rank: Apprentice
Rating: 0%, 0 votes
my paper is not feeding through the printer properly it is pulling to one side
Was this helpful?
Yes
No
Solution #3
posted on May 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
You can try calling Lexmark at: 1-800-LEXMARK. The Technical Support person I spoke to was helpful.
Popular Solutions for Lexmark X5470 All-In-One
Questions and Unsolved Problems for Lexmark X5470 All-In-One
Do you recommend Lexmark X5470 All-In-One InkJet Printer?
Answer
Answer
hi my son pulled out some kind of strip on the printer and i was wondering if i'm able to fix it and... (More)
Answer
i cant get my printer to install after rebooting my computer
Answer
When you turn plug it in it lights up but does nothing, no buttons work but its on. The ink... (More)
Answer
I installed the Lexmark X5470 no 33 colour cartridge bought new (not refilled) and it still says... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
