Question about Toshiba Tecra 8100 Notebook
Toshiba tecra8100 i have problem with bios power on password, can you help me to give me another way to solved that thnk you very much omar
  • Speed66 May 11, 2010
    Just need to know more for a better idea - What were you last working on? Are you getting a bios error or how do you know it is a bios problem? Can you reboot and select Setup just as it powers on? (usually F12 or delete button just as you see power up graphic). Start in safe mode?
    Novelist:
    Champion:
  • 226 Answers
If it's a tecra 8100 model, the power on password can be removed. You can either make your own parallel port adapter that will short out the password (I've done that), or you can buy one (like on ebay) and that'll get your bios password removed.
Posted on Aug 27, 2008
Toshiba Satellite L455d-S5976 Bios password unknown then shuts down?
Remove the RAM cover and RAM. Underneath the RAM is two lands. Short the lands whilst powering up. Switch off and replace the RAM.
Apr 15, 2014 | Toshiba Satellite L455DS5976 Notebook
I have a Hp laptop 610 , i have set a bios password,i still memorize it and i want to cancel it..when i boot my laptop it asks me for the password..i want to cancel this..it only gives me an option of...
Hi Omar,
I understand your problem , All you need to do now , is to go in the security settings of your BIOS and change the protection type.
If you have kept the protection on system mode then it will ask you for a password every time you boot your laptop.
You need to change this to BIOS mode or the other mode which is present and it would solve your problem.
Hope this helps...:)
Aug 29, 2011 | Dell Latitude D610 Notebook
HOW TO RESET BIOS PASSWORD ON A TOSHIBA SATELLITE LAPTOP L45 S7409 DO I FLASH THE BOARD OR PULL THE BATTERY OR BOTH. CAN I EVEN DO THAT? WHAT IF I PULL THE MEMORY OUT REMOVE THE HARD DRIVE AND THEN PUT...
Hi!
The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine.
Or you can try using a Backdoor BIOS password, these passwords are typically used for testing and maintenance. Manufacturers typically change the backdoor BIOS passwords from time to time.For Toshiba, you can try using Toshiba as the password. I hope that helps.
Apr 17, 2011 | Computers & Internet
How do I deactivate the password from BIOS set-up. My daughter forgot her password!
Try type this password : Toshiba ( If I could be offurther assistance, let me know. If this helps or solves the issue, please rateit and give a testimonial for my response.
Mar 11, 2011 | Toshiba Satellite A300-0CF035 Notebook
I have problem in my laptop that when i am trying to start it shows 'enter Password' in blue screen with black background on the screen.
There is a documented problem with this unit that sounds like what you are experiencing. In the link at: http://www.insidemylaptop.com/toshiba-satellite-a105-laptop-sets-bios-password-by-itself/ you’ll find a couple for links to possible solutions.
You can call Toshiba to explain your problem. As I understand it, they will remove the BIOS password at no charge even if the laptop is out of warranty. Both of the posted solutions have you doing things that are farily technical, either from a dissassembly standpoint or a software standpoint. If you don't thnk you'd be comfortable and have time to wait until business hours, I'd suggest you call Toshiba.
One you have it resolved you should upgrade the BIOS to the latest version by downloading and installing from the Toshiba web site to prevent it from happening again.
Jun 21, 2010 | Toshiba Satellite A105-S4164 Notebook
Solve Your "toshiba satellite a300 PSAG4A02E00M PASSWORD" Problem dont know it as was given as a gift before mate headed overseas! Been sitting for a while and have asked mate but now he cant remember...
Hi thanks for asking, when you start the computer and it ask you for password click on the arrow it will give you the password hint simply give the hint to your mate and that should help. You ca also start the computer and when it ask you pr password if its windows xp you can press Crtl+Alt+Delete all together twice and type administrator in the space and press enter, this should give you access.
Jun 13, 2010 | Toshiba Computers & Internet
Please help me !! i need Toshiba A135-S2276 PW cmos default .
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 04, 2010 | Toshiba Satellite A135-S2276 Notebook
My Toshiba boots up with Black screen with a blue box saying Enter Current Password: in white lettering.
i think its power on password The Power On password is set in the System BIOS options. It prevents unwanted users from accessing the computer. By default, does not set the Power On password. If you set the Power On password in the System BIOS options you will be prompted for it immediately after you power on the Notebook PC
if you dont know the password go for a toshiba serviceing center for solve this
Oct 13, 2009 | Computers & Internet
How can I delete bios password?
to delete a BIOS password you have to open your system and take out the battery(small cell). then insert it back and restart your machine.
hopefully this will solve ur problem.
if this doesnot help just resort back to me and i'll give you another solution.
Hitesh
9923888524
Sep 02, 2008 | Toshiba Satellite A215-S5822 Laptop
Satellite A215-S7416 Bios Password
There is a jumper that will clear the BIOS password on most of the newer Toshiba laptops such as this model. Here is a link to an article showing where the jumpers are located on various models of Toshiba laptops.
http://www.ccl-la.com/blog/index.php/clearing-bios-power-on-passwords-on-toshiba-laptops/
I hope this helps, if so please rate my solution.
BuddyMc
Jul 17, 2008 | Acer Aspire 3680 Laptop
Toshiba Tecra 8100 Notebook Logo
196 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
