Question about Ovens
Control panel for Lang Oven Model# EHS-LMOR
Good Day!
Please help us locate in the bahrain, qatar or saudi arabia spare parts for control panel of our convection oven. The brand is Land Oven, Model is EHS-LMOR with the serial of V48422.
Thank You & Best Regards
Christian
I work for a company in the U.S. that supplies repair parts for all commercial kitchen equipment. If you would like to contact me feel free to email me at michael.albertson@3Wire.com
Posted on Oct 30, 2008
My fridigdare oven door won't close I have order new hinges for it but they sent me a motor for it will this fix it?
eh? a motor no that will not fix the issue contact them back and tell them you want the hinges the motor is for the door lock actually what is the make and the model number of your oven and I can see if I can locate the correct part number for your unit I await your reply and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation Thanks Rick
May 04, 2011 | Ovens
I HAVE GLEM GAS COOKING RANGE PURCHASED 6 YRS BEFORE FRM SAUDI ARABIA. NOW IN INDIA CHENNAI. PLS LET ME KNOW THE SERVICE CENTRE DETILS
Please give me details of Glem gas cooking range service centres in Kerala . My id -mecentpl@yahoo.com
Nov 14, 2010 | Ovens
Oven wont heat
Hello, It could be that the EOC is bad but have you checked both sides of the breaker? as you may already know the 220v is on 2 breakers, although you may see the clock still working you still have 120v to the control side, the 120v breaker for the heater side of the cuircuit could have popped...If after checking the breaker you have a full 220 then I would have to say it's going to be a problem with your EOC or high limit if this model has one. Mike
Sep 03, 2009 | Lang Manufacturing EHS-APM Electric Oven
Programming a Lange Oven
go to partstown.com the have the manual for your oven in the top right corner
Jun 17, 2009 | Lang Manufacturing EHS-APM Electric Oven
I need to locate a spare parts list
Hi, this should help you with your parts search. i have located a TC oven spare parts list that should help. click below to be directed.
CLICK HERE
May 20, 2009 | TurboChef C3 Single Oven
Need instructions on how to program all ten buttons for different temperatures for we have no manual that shows us how. We manually programmed button number 1 for 350 degrees F and it works, but can'
http://www.langworld.com/lang_cd/Operate%20Manuals/CNVTOVEN/Op%20Convections.pdf
Check out this web site for your manual. The model EHS-APM is not listed but there are other units with multiple programming options. You will have to browse somewhat but what you are looking for is probably there.
Good Luck and hope this helps.
May 17, 2009 | Lang Manufacturing EHS-APM Electric Oven
Electric Oven Problems
If it is a fan assisted oven, and the fan is working, then you need to fit a new oven element.
This is located at the rear of the oven where the fan is. Plz rate my solution.
Thanks.
Jan 13, 2009 | Lang Manufacturing EHS-APM Electric Oven
I have a Lang Ecoh-ap-2080r (Dennys Restaurant) im trying to find part number for Timer
If your model # is ECOH-AP208DR, Electric Half Size Computerized Convection oven, the timer is as follows: 2J-30800-05 Timer Elec. 1hr 24V. Please check the time range of 1 hour and voltage on old timer be insure this is correct.
Dec 09, 2008 | Lang Manufacturing EHS-APM Electric Oven
Lang Platinum series convection oven
I believe the fan is supposed to rotate one way, then stop and spin the other way, ie. clockwise, then counter clockwise. Did the service guys check this? what service company did you use? You probably already know this but make sure the sides of the pan are NOT touching any of the sides of the oven. I work for a service company myself and I have to say if I got this call and neither of those two things solved it, I would be stumped!
Jan 07, 2008 | Lang Manufacturing EHS-APM Electric Oven
Lang Oven EHS-PP
WB, Your thermostat is shot and must be replaced. The most difficult part of this job is locating one to replace it with. Have the complete Model and Serial number handy... First, try locally. Call a local Commercial Kitchen repair/parts house. Surely theres one nearby, they work on all McDonalds, Wendy's, Restaraunts, etc... cooking equipment. Second, contact the manufacturer; Star Manufacturing International, Inc. 10 Sunnen Drive St. Louis, MO 63143-3800 Phone (314) 781-2777 (800) 264-7827 Fax (800) 264-6666 After you have it, SHUT OFF THE POWER AT THE BREAKER!!! Now try to turn the unit on to VERIFY you have no power. Then remove the t'stat knob. Now remove the screws holding the control panel in place. Tilt the control panel out toward you. Now you can see the t'stat and see how the sensor bulb is routed. (HINT: Take a piece of paper and draw the back side of the t'stat's wire connection locations and wire colors/numbers, BEFORE removing anything.) Remove the wires and the t'stat and route/wire the new one the same way. Another tip; Be extremely careful with the sensor bulbs capillary tube (the small tube connecting the bulb to the t'stat). NO 90 DEGREE BENDS ALLOWED! It is a hollow tube, if it's piched/kinked you can throw it in the trash and buy yourself a new one. (It came packaged as a coil for a reason) As you uncoil it, go slow and easy.
Aug 22, 2007 | Lang Manufacturing EHS-APM Electric Oven
Ovens Logo
161 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
