Question about Xerox DocuColor 12 Printer
Black colour prints faded
I am trying to print a page which has a lot of black on it in large blocks.
It comes out faded when I print on 300gsm but when i print on160gsm it is fine.
    President:
  • 2,072 Answers
Have you adjusted the settings on the machine and in the driver to heavy stock? That will make a difference in the transfer of the image adn the fusing.
Telling the machine you are printing onto heavier stock makes a differenec. if this is a print job, it will have to be changed on the machine and in the print driver. The machine will ask you to confirm the paper settings when you add paper.
You have to select the paper type in the driver.
Posted on Mar 17, 2008
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
My MP600 will not print documents. It will print a scanned document i.e. scan the doc and print from the image. It will print a webpage. It will print a copy it makes but it is blue instead of black....
If colours are faded I would recommend running several cleaning/deep cleaning cycles to try and pull through the colours. It is difficult to say without seeing the print quality, but it sounds like an issue with a partially blocked printhead within the printer.
The printing in blue would suggest to me that one of the blacks in your printer is blocked. Were all 5 colours present on the nozzle check?
Jul 31, 2013 | Canon PIXMA MP600 all-In-One InkJet...
Hp officejet 4255 black colour print not very clear
Select print in grey scales only in printer properties while shooting the print command, printer is using color cartridge instead of mono cartridge..
Jan 11, 2012 | HP OfficeJet 4255 All-In-One InkJet...
Faded lines of black across part off printed page
please you used the colour printer ? if yes then your check the csrtridge a refeling the towner and service the cartridge and service in printer and aply the print is ok.
Sep 22, 2009 | OKI C9300 Led Printer
My printer has just stopped mid printing, status light is red and the light under the black dot is red suggesting the black toner is the problem. The print on last page printed didn't appear faded and I...
yhe problem is that you exceed the amount off alow data go to printer options and select print from computer (it will be a lot slower) but you will solve your problem
Jul 28, 2009 | Samsung CLP 300 Laser Printer
Faint area down left side of page
When you say "Cleaned the lens" I presume you mean the four LED print heads. Use a spirit to clean them with if the toner dust is hard to remove. I usually just use a finger and wipe the entire length. Make sure there is no foreign item laying on the drum top where the black plastic film is as the led head may not seat properly on it. Clean all the silver high voltage springs down the left side of the printer. They make contact with the drums. If you still have a problem then try printing solid colour blocks ie Yellow, Magenta ,Cyan and Black . This will identify which colour is giving the problem . Change that drum and all should be well.
Jul 26, 2017 | OKI C3400n Laser Printer
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
Hp psc 1210 all in one colour problem
The cartridge may be defective. I had that happen so I returned for another and it worked fine
Aug 24, 2008 | HP PSC 750 All-In-One InkJet Printer
Wrong colour
This could one of a few fairly major problems. The easiest way to track down the fault is start by replacing the consumables - make sure you install them in the correct positions - it is possible on the C1100 to put them in the wrong places!! Change the toners first. Most importantly the magenta and yellow. Print several pages. Use MS Paint or similar to create a page with all four component colours on (cyan, magenta, yellow and black)in large blocks (see image below) and print them full page. Now look at the print and see if any one colour is missing or has reduced density. If you have a spare PCU you should but that in next. Let me know what the print outs look like and we will progress to the next step.
Aug 13, 2007 | Epson Aculaser C1100 Printer
Colour faded
Hi Desperate for help I had a similar trouble with my printer it turned out that when I bought a replacement ink tank they gave me a photo quality cartridge and you can't mix them you need all photo quality or all plain cartridges check for that hope this helps
Jan 12, 2007 | Canon PIXMA MP760 All-In-One InkJet...
Xerox DocuColor 12 Printer Logo
196 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
