Question about Toshiba Satellite 5005-S504 Notebook
Problem with keys used to enter the cmos
Excuse me sir, my laptop has the problem with the key to enter the cmos. i don no which key? could you tell me pls by my email. mp3finding@gmail.com
  • 655 Answers
For Toshiba notebook PCs manufactured since the introduction of Windows XP, one or more of the following methods will be effective:
  • Toshiba Hardware utility method: Run the Toshiba Hardware utility from the Toshiba Console. It may also accessible (as 'HWSetup') from the Windows Control Panel. Changes to some of the settings will require re-starting the computer. This method is the only way to access the BIOS settings on some notebook PCs (Satellite 5000 series, for example). (For these machines, pressing and holding the F12 key immediately after powering-on the notebook will allow you to alter the notebook's boot priority.)
    If the Toshiba Hardware utility is not present, try the F2 key method and the Esc key method (see below).
  • F2 key method: Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
  • Esc key method: Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
For more information search on toshiba web.
Thanks
iqbal
Posted on Mar 17, 2008
Reset CMOS on IBM 2847
  1. cmossave.jpgEnter CMOS setup.
  2. In CMOS setup look for an option to reset the CMOS values to the default setting or an option to load the fail-safe defaults. With many CMOS setup screens there will be a function key to do this; for example, the F5, F6, F9, F11, or F12 key like shown in the picture to the right. Other setups may actually list an option that you can arrow over to using the arrow keys and press Enter.
  3. When found and selected you'll likely be asked if you're sure you wish to load the defaults press Y for yes or arrow to the yes option.
  4. Once the default values have been set make sure to Save and Exit and not just exit.
May 14, 2012 | IBM Computers & Internet
Bad check sum cmos
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Nov 18, 2011 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
I don't know my security code
if you are referring to a password protected hard drive
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Hope this helps you
Sep 13, 2011 | Computers & Internet
I have lost the bios password... any body help me to recover without opening case
This is a tricky one because the BIOS password is made to be the hardest password on a computer to break. Some manufacturers allow you to enter BIOS without the BIOS password but most do not. Here are some troubleshooting methods starting with the easiest and moving on to the hardest.
To enter BIOS hit the F2 key repeatedly as the computer boots up. You should enter BIOS after the first loading screen. If this does not send you into BIOS, try the ESC, DEL, and F1 keys. Once in BIOS find where you can set the password and reset it or enter a blank password as your new password.
If you can't access BIOS or are prompted for a password once you enter BIOS, try the following methods to flush the BIOS password cache:
1. Contact your manufacturer's support and ask if they have a backdoor BIOS password that they will allow you to use. This works to allow you to enter that password instead of your own and easily fixes the whole problem, but not all companies will tell you their password. You can also do a google search for your manufacturer's backdoor BIOS password since many of them have been discovered.
2. Send your laptop to your manufacturer to have them reset the password manually, although this takes an undisclosed amount of time and they will often make you pay a fee if you are not under warranty.
3. If you don't want to pay your manufacturer, open your laptop and locate the motherboard. On the motherboard there is a CMOS battery, if you don't know where this is use your PC manual. Remove the CMOS battery for an hour and then place it back on the motherboard. This should reset the password. After this turn on your computer and enter BIOS. This will reset all your BIOS settings so it may take a few minutes to open. After it is open, just exit BIOS and everything should be working properly. Just be very careful when opening the laptop and handling the CMOS battery because you can severely damage your laptop if you don't handle it properly.
Thanks for using FixYa and good luck!
May 23, 2011 | Computers & Internet
My laptop is stuck on safe mode, and no matter what I try I cannot get it off of safe mode. I am not able to access any of my programs that I already have downloaded onto my laptop, and I cannot download...
During the boot process you will see on the screen to press a certain key usually delete to enter setup
hope this helps
don
Feb 12, 2011 | Toshiba Computers & Internet
HOW TO REMOVE PASSWORD FROM BIOS
Dear Sir,
To remove password in your BIOS
1. Turn off your PC ang remove power cable
2. Open your PC Casing and find the CMOS battery
3. Remove CMOS Battery Located in your Motherboard
4. Most Bios Battery is CR2032 Lithium Battery
5. After removing battery Short circuit the Positive (+) and Negative (-) pin in your bios terminals using a metallic screw or any metal to connect both terminal.
6. Put back the CMOS battery to its original location.
7. Turn on your pc and press F2 or delete depending on your Motherboard BIOS key.
8. Check if you can enter the BIOS settings.
Hope this will help,
Markus
Feb 04, 2011 | MPC Computers TransPort X1000 Notebook
How to enter cmos setup?
Dear Don't worry, there are some options you will have to press or check one by one "F1or F2 or F8 or F10 or F12 or del. Now, You can enter in CMOS setup.
Aug 04, 2009 | Toshiba Satellite 5005-S504 Notebook
For registration of pvplayer.3.4
You have to contact the Vendor/Site who sold you this Software and they'll provide you with the Activation Key.
Jul 01, 2008 | Nokia 7610
Remove bios pass word
you can remove the bios password by removing the battery wait for 10 to 15 seconds then return power on. you can also reset this by transferring the cmos clear pins from pin1-2 to pin3-4 wait for 10 seconds then return to pin1-2 then power on.
Jan 02, 2008 | Toshiba Portege R100 Notebook
Toshiba Satellite 5005-S504 Notebook Logo
340 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
