Question about Whirlpool LSB6200KQ Top Load Washer
How do you get to the motor coupling?
Whirlpool model 6lsc9245hqo we have removed machine casing. can you help please?
  • Roger Hiebner Jul 14, 2008
    Part of the clutch has come loose .I need to know how to strip down the machine to replace the complete clutch assembly.
    Sergeant:
  • 351 Answers
Once you have removed casing,removr two clips that hold pump on and hold pump to one side then two more clips hold the motor on remove them and the motor will come off (undo the motor plug and two wires to motor cap).then you have access to the drive coupling.
Posted on Mar 17, 2008
SOURCE:
Whirlpool ultra care ll, how to replace rubber coupling?
Flip control panel up, take off cabinet, remove pump off motor, remove motor, and your coupling is on the motor and gear case .
Dec 30, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer top load agitator does not work
Whirlpool top load machines have a coupling beyween the motor and the gearbox..This coupling can fail with age or if the machine is overloaded. The pump should still work even if the coupling is broken..If this is the case then it's not a big job...You need a tech who knows the tricks, and it won't take long to fix....Good luck....Nomess
May 14, 2010 | Washing Machines
Need to replace coupling between tub and motor? How does tub come off?
If you are referring to the motor coupling, it is actually located between the drive motor and teh gearcase. You DO NOT have to remove the wash tub in order to access and replace it. The following link explains step-by-step how to replace a motor coupling on a Whirlpool top loader:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
If you have questions about this repair, or if the model washer you have differs from the one you listed this question under, please post back and let me know. I hope this helps you.
Apr 19, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a whirlpool washer and it is making a loud clicking noise and is barely spinning.
Hello, from the limited information I have this sounds like it's going to be a broken coupling. Kenmore's, Whirlpool's and Ropers are direct drive machines this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like: 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chassis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be careful to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks! P.s Don't forget to unplug the power cord before servicing.
Oct 20, 2009 | Whirlpool Washing Machines
Washer Will Not Spin - Need to Replace Coupler?
Two Clips (about 6" long and held to the motor with 5/16" head screws) hold the motor and pump assembly in place. Another two hold the pump to the motor. To do this job you need not remove pump from motor.
This job is much more easily done if you remove the outer case from the machine. See Link below for service manual:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Aug 23, 2009 | Washing Machines
Whirlpool washer, model # LSQ9010PG will not spin water out. Sounds like it is straining during spin cycle, even with no clothes in it?
Hello, from the limited information I have this sounds like it's going to be a broken coupling. whirlpools are usually direct drive machines, this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupleing looks like: 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chasis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be carefull to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector inbetween. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks!
P.s Remember to unplug the power prior to servicing.
Aug 15, 2009 | Washing Machines
Weak spin, will drain water, but won't spin
Hello, from the limited information I have this sounds like it's going to be a broken coupling. Kenmores are usually direct drive machines made by whirlpool, this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupleing looks like: 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chasis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be carefull to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector inbetween. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks!
Aug 05, 2009 | Whirlpool Washing Machines
Whirlpool washer agitator not turning
hi there,
can you provide me with the model # please?
most older machines have only a 1 piece agitator but the newer machines are a 2 piece.
let me know and i will try and help you put it back together.
thanks
Sep 28, 2008 | Whirlpool Washing Machines
Washer does not spin or agitate
you need to remove the cabinet to expose the washer. once you do that you need to remove the 2 clips that hold the pump to the motor. then remove the 2 1/4 inch screws that hold the 2 clips onto the motor. ( remove the wireing connector first) remove the motor and Im sure you will find that the coupling need to be replaced. There are 3 parts to the coupling. 1 rubber and 2 white plastic parts. replace the coupling and install everything in reverst. your washer should work fine after this.
Jul 22, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSB6200KQ Top Load Washer Logo
37 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
