Question about Sennheiser RS 140 Consumer Headphones
My sennheiser headpahone is not working
The wire of my sennheiser headphone is slightly removed from the stereo pin because of that it is not working..........plzz give me a solution.
I had that problem before. I thought something was bent. Actually all you have to do is make sure the headphone are pushed all the way up on both sides.
Posted on Mar 29, 2008
Sennheiser head-phone cable problem?
This should help, skip to the part where he starts soldering the parts
http://www.youtube.com/watch?v=OhnXUQRQ4u4
Feb 17, 2013 | Sennheiser HD428 Stereo Headphones
There's no sound coming out from left earphone
Try your headphones in a different audio device. If the problem persists than the headphones have a split in the wiring for the left earbud. If you are under warranty then Sennheiser will happily repair your headphones.
May 03, 2011 | Sennheiser Sport II CX 380 Stereo...
Only the right ear is getting sound on my brand new HD 428s. I've tried other audio programs and other headphones, and all work fine.
You have to trace the wiring inside of your headphone because probably there is an open wire or short wire inside of your headset.You need a multitester to determine where is exactly the troubled wire. Have a nice day!
Jan 04, 2011 | Sennheiser HD428 Stereo Headphones
My Sennheiser HD 205 suddenly had a problem with its jack. You have to move its top, nearest to the cord, to get a sound on the other ear, probably it was pulled and something went loose. I spliced it open...
The two copper wires on your headphones are independent grounds for each channel. Twist them together and attach them to the ground cable ( black) of the new plug. The colored wires of the headphone correspond to the live wires of each channel, and the plug should have the same colors. Wiring together the grounds will not affect in any way the stereo separation, it is just that each ear needs its own ground. Cheaper headsets just transfer the ground from one ear to the other one through the metal headband.
Oct 06, 2010 | Sennheiser HD 205 Professional Headphones
I am trying to replace the jack on my PX100's. I have a replacement jack and have worked out which colour wires to connect to the various pins. Problem is resin cored solder suitable for other electronic...
See my tip on headphones jack/cable problems. Also sometimes they put on a special coating on the wires. You have to scrape the wire or file it to remove it. Spit is also good at making the solder stick!
Aug 20, 2010 | Sennheiser PX 100 Consumer Headphones
My earphones' audio isn't right. I have to twist the wires to get it fixed. Sometimes, it only has sounds on the left or on the right or nothing. What should I do?
You have fault in the wires that has been twisted and open/ shorted within losing the connectivity. The best thing is to get this replaced if you can do the work by yourself, you will have to buy the shielded twin core wires, one headphone stereo jack, open the earpiees carefully- it is tricky,so do it gently, solder the wires in accordance with the lead and shield on either sides and then connect to the stereo headphones. Hope this wil work out for you. Good day
Jul 05, 2010 | Sennheiser MX 360 Inearphones High...
Replacement connector for Sennheiser PX 250 doesn't work...
The bare copper conductor wire is the screening/common earth to the two signal wires of green and red. The important connection is the copper wire which goes to the jack plug earth which is the section furthest from the tip. The other two are the left and right signal connections. If you get these the wrong way round you will just have to swap them over. Check if they are the right way round by using the balance control on your amplifier or whatever. Have you checked that the problem is not with the headphone amplifier within your equipment? Don't rely on OK sound from loudspeakers as the headphones may be fed from separate op-amp output chip. Try another pair of cheap and cheerful headphones to make sure.
Oct 03, 2009 | Sennheiser PXC 250 Consumer Headphones
Sennheiser RS 140 Consumer Headphones Logo
703 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
