The baterie wont start and it is turn off! - Audio Players & Recorders
  • Davismap Mar 21, 2008
    When connected to the computer or a wall charger, the symbol of charging shown for 30 second and the battery won't charge anymore, anthought I left it a whole day.
  • jeni6648 Apr 10, 2008
    i turn it on it loads the T10 logo then shuts off
  • 24 Answers
Physical damage or not using a battery or holder can affect usage on your mp3 if its rechargable chnage device to see what happens
Posted on Mar 17, 2008
My xbox 360 controll wont turn on unless my rechargable batery is fully charged
just buy a plug in and play that should solve the problem and keep the plug in
Jun 18, 2012 | Microsoft Xbox 360 Controller
Daewoo Leganza turns over but wont start, just getting a clicking sound from under the hood. Any clues to what this may be?
you need two people one at the key and one at the starter first check batery connectionsmake sure there clean .then check cableswiggle to see if there loose .than check battery do the head lights come on bright . not ok than repair batery conn cables or charge batery. if ok than follow the click to the starter hopefully, cilinder shaped item mounted to tranmission engine connection point.( while in park or nutral) they turn key to start position you tap on starter case .if it cranks over you need to replace starter.
Jan 30, 2011 | Daewoo Leganza Cars & Trucks
I have a cobra alarm on my motorcycle.I left the lights on and the battery died.now i hav no spark and the bike wont start.can u help?
HI, SOUNDS LIKE THE IMOBILISER HAS NOT TURNED OFF, YOU HAVE NOW RECHARGED THE BATERY, I WOULD THINK THAT THE BATERY INSIDE THE ALARM UNIT IS ALSO FLAT, CHECK THE FUSE FITTED TO THE ALARM HARNES
, IT COULD BE YOU HAVE DISCONECTED A WIRE OR BLOWN A FUSE WHEN REPLACING THE BATERY, RE CHECK ALL CUT OFF SWITCHES, SIDE STAND IN THE UP POSITION, AND ALSO TRY RESETING THE IMOBILISER
Jan 10, 2011 | Harley Davidson FLHRI Road King...
It wont crank like not getting power
ok sounds like you have a dead battery
1) if turns but slowly:
posible causes:
1.1) old dead batery/
or underchaged battery >check altenator in this case
did you leave your headlights turnt on and drained the battery of its charge?if so get a jump start and then run the car for 30-45 mins to rechagre the battery
if you have at your disposal anothere batery that you know has a good charge
try starting your car with that batery(not using jumper cables) hook it up!
if the slugish turn over is still there
1.2) check your wire conections for corision this means completly disconecting 1 lead at a time (only on one end of that lead)and cleaning them with a wire brush or some sand paper.
(on the battery and the starter also the ground strap conection to the frame.)
2) WONT TURN OVER AT ALL:
posible causes:
2.0) dead battery >try charging it>get a jump start
2.1) blown turnkey igntion fuse
2.2) blow fuse for main har nes wires
2.3) bad starter
2.4) corosion on wire conection (most often the batery terminals)
2.5) starter replaced and hooked up incorectly.
2.6) alram system preventing the turnkey igntion system from getting power
Feb 24, 2010 | 1994 Mazda 626
Bike wont start turn over till batery dies. where
It will have a fuel filter in the fuel line (should be easy to find) but does not have a fuel pump. Firstly i would check you have spark on all cylinders as this is the most likely thing to be going wrong. Once you are sure you have spark you can start trouble shooting fuel and air delivery problems.
To check for spark remove a sparkplug, insert it back into its HT lead. Place the threads of the sparkplug on the engine block and crank the engine. A strong blue spark should be visible.
Aug 31, 2009 | 1999 Suzuki GSX 600 F (Katana)
Car wont stay started... but will start then turn off
make sure that the alternator and the cabels are good .
Jul 15, 2009 | 1998 Oldsmobile Cutlass
 Grubhead
Grubhead
