Question about Microsoft Windows 98 for PC
WHAT IS CFTMON.EXE
ERROR IN WIN XP CFYMON .EXE
  • Microsoft Master
  • 19,396 Answers
Cftmon.exe is normally a process installed by microsoft office to control the language bar.
Here is definition:
"The cftmon.exe process is a component used in MsOffice to perform language related functions. It is closely tied to the 'Language Bar' present in MsOffice, so if you use the Language Bar you should leave this process running. If, on the other hand, you do not use the language bar, you should terminate this process to free up system resources. cftmon.exe is an application that does NOT appear to be a security risk"
It remains on the computer even after you remove office. It is not a dangerous file, if you want to eliminate it you need to act on the registry with regedit, here are instructions.
Some spyware may rename itself cftmon.exe, to disguise as the office process.
Use spybot if you think it can be a spyware hiding behind cftmon.
Posted on Mar 17, 2008
SOURCE:
Re: to call of duty wont run in win 8.1
Right click> Properties>Compatability>Run for Windows XP (SP3) or lower
Dec 27, 2013 | Activision Call of Duty 2 for Windows
Tip
WINDOWS LIVE COMMUNICATION PLATFORM ERROR/ LOGIN PROBLEM
if you have problem with msn messenger 2009 not working properly in win xp sp2. you can update your windows by download "WindowsXP-KB936929-SP3-x86-ENU.exe" by search in google from microsoft site. the file is of 316 MB. then your computer became win xp sp3. now install msn messenger it will work properly.
on Dec 22, 2009 | Microsoft Windows Live Messanger
Receiving error message: WlanMon.exe - Entry
Try a reinstall of the software sounds like that wlanapi.dll isn't being "Registered" If installing on Vista or Win 7 use Admin mode and try Compatabilty Mode for XP SP2.
Feb 03, 2010 | Blitzz Technology (BWA611) Router
Csrss.exe encountered a problem and needed to close. This error i am facing when i logged as admin to Win xp sp2 O.S
Hi swancul,
Try the following link and follow the directions on that page to download, install, and run free software to fix this problem. Hope this helps! Hal
http://www.exenerd.com/exe.php?seed=Csrss.exe
Jun 03, 2009 | Microsoft Windows XP Professional SP2
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
Explorer.exe Application Error in Windows XP Professional SP2
Bring a bootable XPSP2 cd & boot from it ....when installling choose C: & format ..
Nov 27, 2008 | Computers & Internet
Ran a search and destroy program and it deleted system files
WoW, stay away from that program, which was it?
To correct this, you can do one of two things:
first, can you get to you desktop ok? And do you have you XP cd handy? (if you cannot get to your desktop, start with the second thing)
If the answer is yes to both questions, put your XP cd into the CDROM, then go to start >run> type in sfc /scannow in the run box. This will attempt to fix and replace the missing files.
Second thing, if the above does not work do the following:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just re-installs the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 08, 2008 | Compaq Presario 5000 PC Desktop
Halo 2 for pc
The reason is, it only happens when you try to install Halo 2 on Windows XP.
The Game gets installed perfectly on Windows Vista
Because, I have installed and played the game on Windows Vista. But, when I de-graded my OS to Windows XP and tried to install the game. It gave me the same error message.
So, if your OS is Win XP then try install on Win Vista if you have it or on your friends PC.
But if you are already on Win Vista then please do let me know.
Also could please let me know whether your trying to Auto install the game or you are manually trying to install the game by clicking Step.exe?
I would be glad to find some help for you in this regard.
Jul 27, 2008 | Microsoft Halo 2 for Windows
Download driver for Compaq PresarioC700
how to download the audio drivers of comaq c700 laptop for win xp
Jul 22, 2008 | Computers & Internet
Xp error message
Try the following:
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to and delete the following entries:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc2k5" = "C:\WINDOWS\SVIQ.EXE"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"Fun" = "C:\WINDOWS\system\Fun.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc" = "C:\WINDOWS\dc.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"run" = "C:\WINDOWS\system32\config\Win.exe"
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\"Shell" = "Explorer.exe C:\WINDOWS\system32\WinSit.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load" = "C:\WINDOWS\inf\Other.exe"
  5. Exit the Registry Editor.
Nov 10, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows 98 for PC Logo
167 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
