Question about Dell Latitude D800 Notebook
D800 Video Display
Have only vertical lines from top to bottom of display when booting. I get nothing when I hook up an external monitor. Video Card?
  • Anonymous Apr 22, 2008
    i get vertical lines as well, but then when i move the monitor back and forth they go away briefly. is there anything i can do to put the ribbon back into place?
  • Dell Master
  • 19,396 Answers
If you get a clean picture when connecting esternal screen, then it is just the lcd flat ribbon LCD cable that is out of place, otherwise it is the videocard.
Posted on Mar 17, 2008
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
Screen particially blacking out with vertical lines at bottom of my DELL laptop. at the bottom of laptop screen there are vertical lines @ 2" they are blue, dark gray,white, purple, light green lines....
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Jul 31, 2011 | Dell Inspiron 1525 Laptop
They are flashing vertical lines in various colors as well as letters showing
hook an external monitor. if its the same problem, video card is the problem. if it has a clear display, then you need to replace the lcd.
Apr 09, 2010 | Microsoft Windows XP Professional for PC
Monitor problem
If it is clear with no lines when it boots and you see the Bios settings and splash screen it maybe ok... it may just be your Display Settings in your Opperating System. Use F5 to go into "Safe Mode" to reset. You toggle F5 at boot and select Safe Mode.
See if you can use an External Monitor. You may need to use the Function F4 Key or one of those to toggle the Monitor. If it works on the monitor and not you display then it could be your display screen. Fixable for 250-350 dollars typically.
If you don't get to Safe Mode sucessfully and not display on the external monitor... could be video card... and that meens motherboard replacement. Part is 200 and labor about 150-200.
Jan 24, 2010 | Acer Computers & Internet
WXGA Display for Dell Latitude D800 Problem. When
replace either your cold cathode screen lamp or, your inverter board in your display
Aug 28, 2009 | Dell Latitude D800 Notebook
Dell laptop connected to 1209s projector...dell page indicates searching for signal and can't
Using the Display When you start the computer with an external device (such as an external monitor or projector) attached and turned on, the image may appear on either the display or the external device.
Press <Fn><F8> to switch the video image to the integrated display only, the integrated display and an external CRT monitor simultaneously, an external CRT monitor only, the integrated display and an external DVI monitor simultaneously, external DVI monitor only, and external CRT monitor and external DVI monitor simultaneously.
May 15, 2009 | Dell Latitude D800 Notebook
Vertical line in imac 17" core 2 duo intel 2006 model
Attach an external monitor (you may need to buy an adapter to try this) and turn on Display Mirroring in the Display preferences.
If the same symptom shows on the external monitor, then you've got a video card problem. If not, I'd say you're screen has some kind of damage of failure.
Sorry, but either one is likely going to require a trip to the Apple Hospital.
At least with the display problem, you could use the external monitor until repaired.
Mar 16, 2009 | Apple iMac G5 Desktop
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
Inspiron 8500 - Display issue
with the external monitor attached press <FN><F8> to toggle between internal and external display. if still nothing then it sounds like the video card.
MANUAL
Check all the connections (especially the ground screws) that was a problem with one I worked on last year.
May 29, 2008 | Dell Inspiron 8500 Notebook
Dell Latitude D800 Notebook Logo
268 people viewed this question
Alun Cox
