Question about Canon Cameras
I HAVE NOW PLACED TWO SETS OF NEW BATTERIES INSIDE CAMERA AND IT IS COMING UP PLEASE PLACE IN NEW BATTERIS AND THEN CAMERA WILL GO OFF? GWYNETH STEPHEN
4 Suggested Answers
  • 28 Answers
SOURCE: No power with new batteries
needs reload battery settings into the camera, contact fuji services
Posted on Apr 04, 2008
BillB-SA
  • 2761 Answers
SOURCE: camera wont power on. I tried 3 sets of batteries
If the camera has recently been dropped it may have lens damage that is preventing it from powering up. If it hasn't been dropped, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries, place them back in the camera, and give them a good charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. "Very Helpful" would be appreciated . .
Posted on Dec 05, 2009
geemarie
  • 876 Answers
SOURCE: I placed new batteries into the camera, however
Digital cameras use batteries p very quickly. Some batteries last longer than others. I buy large multi packs at the big box store near me. When you say two uses, do you mean just two pictures or two uses taking several pictures? You can go to your cameras menu and navigate through it to adjust several of the settings which will save power. You should also be sure that your battery setting is correct while you are there.
Look through your manual to read about the menu settings and battery usage.
Thank you for using FixYa.
Posted on Dec 27, 2010
Shows error on the batteries
If your camera shows error even after changing the batteris, then it will not be an problem with the battery. Please check the setting of the camera once and switch on the camera. Also if the problem still persists, reinstall the software and try again.
Thanks
Apr 01, 2012 | Nikon Cameras
I keep getting a battery flashing signal even with new batteries and it takes one pic and shuts off
Check the type batteries you are using. This camera uses either the alkaline batteries (don't use the cheaper brands, their residual power is much less) or the NiMH [Nickel-Metal Hydride] rechargeables. The NiMH batteries give you greater service and increased life in the camera. Nickel Cadmium batteries are unpredictable for use in this camera.
You may also want to check your battery contacts on the batteris themselves and also the contacts inside the camera. To clean the contacts inside the camera use a reliable contact cleaner. I use either NU-TROL or Deoxit. A quick squirt and cotton bud swirls will do the job. Make sure you wipe the terminals of the battery with it as well. Body oils can partially insulate from conduction. If you can't find a good contact cleaner, I found mine at Baynesville Electronics, 410-823-0082.
Hope this helps.
Sep 05, 2010 | Canon PowerShot A560 Digital Camera
I have installed new batteries but the mouse will not respond. The receiver will light, but no lights lit on the mouse. Did press both ID buttons, but no help.
Remove the batteries again, and check inside the battery slot, for foreign objects or contacts. Try different sets of batteries, and ensure batteries are placed in the correct way and making contact.Test the mouse with computer off first.
Try reinstalling the mouse software on Windows.
If the mouse still has no light after replacing the batteries, and after reinstalling software, then the mouse is defective.
When this problem occurs it is usually because of the batteries not having charge, because they are not placed correctly, or because of a broken contact inside battery slot.
Jan 13, 2010 | Micro Innovations Wireless Optical Travel...
Camera wont power on. I tried 3 sets of batteries
Dec 05, 2009 | Kodak Easyshare C813 Digital Camera
Lens keeps movin in and out (Pentax M20)
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 27, 2009 | Pentax Optio M20 Digital Camera
Why is my camera batteris won't last what type of
You didn't mention whether you're using rechargeable batteries or throw-aways. If rechargeable, I recommend Ni-MH over other battery types. They hold a good charge, and can be recharged about 300 times. Your short battery life may also be due to corrosion on the battery contacts inside the camera which can prevent full power from flowing to or from the batteries. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 26, 2009 | Kodak EasyShare C743 Digital Camera
Put in new batteris and nothing happens. They are
First, make sure that the "new" batteries have a full charge. If you don't have a meter to check them with, try using them to power something else. Also, if using rechargeable batteries, make sure that they are the correct type for the camera. NiCd batteries will not work well in a camera that calls for Ni-MH batteries.
If the batteries are OK, your problem may be due to corrosion on the battery connections inside the camera. Remove the batteries and wipe the camera contacts with a clean soft cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any specks that may have fallen into the battery compartment during cleaning, then clean and reinstall the batteries.
The above clears about 90% of power-up problems, and I hope it works for you. If not, your camera may have a more serious problem that requires repair by a camera shop or the manufacturer.
Aug 20, 2009 | Kodak EasyShare C663 Digital Camera
VQ515 Camera is new. Turn it on. All I see is VitaQUEST
have you tried taking out the batteries and either let it rest a minute then replace them , or just put brand new batteries?
Dec 23, 2008 | VistaQuest VQ-5015 Digital Camera
Lens Stuck Out/Will Not Go Back In
well u have a problem, and u will need to replace the mainboard. if it´s under warranty send it to the repair centre they will replace mainboard for free
Mar 01, 2007 | Olympus D-535 Zoom / C370 Zoom Digital...
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
