Question about Acer TravelMate 272XC Notebook
Acer TravelMate 272 Memory
I want to upgrade to 1gb (from 256gb). The manual states that there are two memory slots which can each take 512Mb.
When I open the memory cover I can only see one memory slot (which is empty).
Can anyone tell me where the other slot is located (with, presumably, the original 256mg fitted)?
  • Richard Wagstaff Mar 17, 2008
    Many thanks for the info.
    Any idea how to remove the keyboard?
    Scholar:
  • 105 Answers
I think in this case the second memory slot is under the keyboard.
Posted on Mar 17, 2008
SOURCE:
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
I have a Toshiba Satellite 1905-S301 that has 512mb of DDR memory currently. I have a stick of 128 that I was going to throw in there to boost performance but when I opened the compartment the there was...
There are 2 types of memory, one for laptops and one for pc.
Your additional stick seems to be for pc from what your saying.
Additional thoughts:
I'm sure you can buy sticks for laptops at walmart or whereever you bought ur laptop. Just make sure it is the same speed type. Example: yours is 512mb ddr PC 5200, you will need to find PC5200, the 512mb and up you shouldnt have to worry about. So do your research before you upgrade or you will burn your laptop.
Sep 09, 2009 | Toshiba Satellite 1905-S301 Notebook
Can I add 1GB memory chip in 2nd slot with a 512MB chip in 1st?
You can upgrade by inserting a 1GB PC2100 DDR SDRAM DIMM. I would put the 1MB in the first slot and move the 512MB chip to the second slot.
The 1GB should cost around $40.
Jul 05, 2009 | HP Pavilion 763n PC Desktop
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
Upgrading Memory on an AOpen MX46-533V
Well yes, in a way the amount of memory should match in each slot. So with two slots you can have two 512MB which will give you 1GB. Or you can get rid of those and use one slot and just put a 1GB stick in it. Finally, you can buy two 1GB sticks, put one in each slot and have 2GB...it is not recommended to put 512MB in one slot and then 1GB in the other slot. That will cause your computer to become unstable..hope this answers your questions.
Please rate this solution.
Apr 09, 2009 | AOpen MX46-533V (91.89U10.061) Motherboard
2 x 1GB Samsung PC2100 appearing as just 1GB (2 X 512MB)
Hi Patrick,
I see you're point. I know this, you can not run "more than" 512MB in any DIMM slot. That is shown at the bottom of page 10 & the top of page 11. You can not run both types of memory at the same time, even though the chart looks like you could. The description term on page 10, states; Users only can install either 168-pin SDRAM Module or 184-pin DDR DRAM Module at one time. (You can't run both). You can run 4x512MB in all banks using184-pin DDR SDRAM. Or you can run 4x512MB in all banks of 168-pin SDRAMs. Total of 2GB.
So you can not run 1GB of memory in any bank.
Mike
Jun 29, 2008 | Jetway V266B Motherboard
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Asrock 775VM800 Motherboard
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Upgrade from 512MB to 1GB
The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
Mar 15, 2008 | ASUS P4B266 Motherboard
Acer L100 memory upgrade
you can open it up and see, take out the ram to see what kind it is
Dec 24, 2007 | Acer Aspire L100 PC Desktop
Acer TravelMate 272XC Notebook Logo
134 people viewed this question
Ekse
Alun Cox
