Question about Daewoo DV-6T955B DVD Player/VCR
DVD/VCR combi will not record quality discs. When disc is inserted it goes through correct process of loading and initialising but does not accept disc for recording.
  • Anonymous Mar 22, 2008
    Have tried DVD+RW and DVD-RW discs and have since cleaned the lens but to no avail. DVD will still not record anything.
  • Anonymous Apr 22, 2008
    My Daewoo DVD Player / VCR Combo will not record on well known brands of +RW DVD disks (e.g. Philips, Tesco).
    It goes apparently correctly (but slowly) through the sequence of initialising the disk and recording when instructed to do so, and after stopping it informs that it is finalizing the disc. However, on a request to 'play' , it shows the disk as empty.
    The only discs I have which record with no problems are some (of unknown manufacturer!) which I bought with the player three years ago.
    Can anyone tell me which brands of +RW discs work with their player, please?
I AM TRYING TO RECORD SOME PROGRAM USING DAEWOO VCR/DVD COMBO WITHEN VCR ON DAEWOO ANY BODY CAN HELP ME ON THIS PLEASE.
Posted on Apr 02, 2008
SOURCE:
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
Cd not reading
This happens sometime when the drop
down menu in the recording program is
not set correctly for the dvd recorder it
may be set for another recording device
or the dvd player. If this in not the case
try removelng the dvd recorder in device
manager and leting it reinstall
Nov 21, 2007 | Philips DVDR630VR DVD Recorder/VCR
I am going out of my mind trying to dub VHS to DVD on my new Toshiba DVR620. Please help!
I have a Toshiba HDD&DVD vcr RD-XV48DTKB will not accept disc or play any disc have tried several makes even new ones it just loads then says error cannot play eject will not play or record HELP
Jan 22, 2011 | Toshiba DVR620 DVD Recorder/VCR
CAN RECORD FROM VCR TO DVD+R, CAN PLAY DVD ON SAME, BUT CANNOT PLAY ON OTHER DISC PLAYERS. I THINK THAT THIS IS BECAUSE I AM NOT FINALIZING CORRECTLY. WHEN AND HOW DO I FINALIZE A NEWLY RECORDED DISC?...
Usually you finalize the disc after loading it with all the desired content (leaving a bit of space for the finalization). So if you are recording a TV show, depending on the setting (SP, LP, XP), you might finalize the disc after recording 4 1/2 shows. The How may vary by model but on my DVD recorder, I find the finalize command in the same menu area as adding a title and initializing a DVD-RW disc. So I press Setup to enter the OSD menu, then go down to Disc (looks like an optical disc) then right arrow to enter the sub menu. Then press down to Disc Finalize and the right arrow again and press enter. Select OK and Enter again. (RW discs can be unfinalized to add more content.) Then wait until the process is done.
I hope this helps.
Jul 09, 2010 | Philips Magnavox DVD/VCR Dual Player
My recorder wont record on new discs
Daewoo DVD Recorder/VCR combi (I believe the model number is DF-4100P it wont record on disc but it will on tape mode plus the drawer in the dvd wont open please can someone send me an answer of whats wrong with it thank you
Apr 05, 2010 | Daewoo DVRS05 DVD Recorder/VCR
DMR-EX98 CANNOT USE DVD RECORD FUNCTION MACHINE THINKS A DISC IS LOADED EVEN WITH NO DISC INSERTED.HDD/VCR OK
This problem has just happened on my dmr-ex98 although perhaps more extreme in that the dvd drive will not read any disc let alone record - makes an attempt to read disc plus phantom disc but gives up. hdd.vcr also ok. Any guidance?
Feb 15, 2010 | Panasonic Televison & Video
Won't accept dvd after loading!
DVD door switch is bad. If you are willing to open it up and soldiering a new one, here is a link to a replacement switch.
Jun 11, 2009 | LG XBR446 DVD Recorder/VCR
My JVC DR-MV7 will play most DVDs and even record, but recently, it stopped being able to finalize. After I get the message saying "finalization has failed," I can't even play the DVD anymore - thus losing...
My JVC DR-MV7 will not accept any disc for playback. I insert a movie disc and it consistently rejects them. After about 15 to 20 attempts, sometimes it will stay and begin reading the disc. It also sounds like some internal components are encountering some resistance (moving parts inside?). Any ideas?
Nov 27, 2008 | JVC DR-MV7 DVD Recorder/VCR
Samsung DVD-R135 / R136 - Will not load blank discs
Hello, First be sure your using the correct disc DVD+ or DVD- RW etc.
I would recomend using high quality discs as players/recorders are very picky about cheap media. Try using Imation name brand discs. They read well in most anything. If it has worked fine & then started having this problem I would first check to see if your using the same discs that have always worked with it & if so then you may want to open the unit & clean the laser lens with a cotton swab lightly soaked in rubbing alcohol. Especially if it has been smoked around or is in a dusty environment.
Feb 15, 2007 | Samsung DVD-R135
Daewoo DV-6T955B DVD Player/VCR Logo
259 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
