Question about Microwave Ovens
Panasonic NN8857 Microwave
How do I change the oven bulb, please?
  • Microwave Ovens Master
  • 9,098 Answers
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
We have *critical* safety & disassembly info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
How do you change a light bulb in a panasonic 1100 microwave oven?
Some microwaves have a small panel on the side which you will need to undo a screw . Open the small panel and unscrew the bulb.
Others have a small square panel inside which may look like card that you can slide out and remove the bulb.
Mar 07, 2015 | Panasonic Microwave Ovens
I need to replace a bulb, the glass cover and the bulb holder for a Panasonic Model NN K652BBPQ. Where can I order these parts please.
Panasonic.com appliance parts.com do agoogle search for panasonic microwave oven parts etc. the internet is your oyster the end result is your pearl
Dec 16, 2014 | Panasonic Microwave Ovens
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
The light is not working in our oven - a Panasonic Microwave Model T 784. Can you tell me the location of the bulb in the oven so it can be replaced. There is no problem with the oven it still works...
Hi, If you put in your search engine
Panasonic Microwave Model T 784. bulb replacement
You will get a selection of web sites. Scroll down and select the 5th site. At the right hand side there is a series of options, chose the top one "howto man" There you will get a step by step guide to changing the bulb in your microwave.
Hope this helps
David
Mar 02, 2018 | Microwave Ovens
How do you change the bulb
You may have a bulb on the right side ,if correct then remove the clock panel and access it from there.If not remove the shell and lift off the microwave cover to get to bulb
Dec 05, 2010 | Panasonic NN-S753 Microwave Oven
I want to change the light in my microwave. Panasonic nn-p704sw. I took apart the covr and foung the light attached to a plastic scockrt. I tried to unscrew but the bulb was tight. should i apply more...
Typically the bulb will unscrew from the socket. If you can remove the bulb and socket with the wire from the microwave (wire hanging from the microwave) you might be able to get more pressure on the bulb to turn it. Keep in mind that the bulb may have been in the oven for several years and there may be a build of grease on the treads of the bulb so it could be really stuck. Put a cloth towel around the bulb and wear gloves so you don't cut your hand if the bulb were to shatter.
May 02, 2010 | Panasonic NN-P794SF Microwave Oven
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Panasonic Model #NN7524A Microwave bulb replacement help
microwave---NN-S335 , 800W Plate exploded , Where can I get another ? From C Carver Feb. 23 , 2009 Thanks
Feb 25, 2009 | Panasonic Microwave Ovens
Panasonic bulb nn a753
First, get the bulb part #F612E4W00AP or equal. Next, you should find a few screws around a plate in the unit through which the light shows through. Carefully remove them and the glass lens. When replacing the bulb, be sure it is in securely.
Dec 15, 2007 | Panasonic NN-T774SF Microwave Oven
Panasonic NN-H664 1200 Watts Microwave
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job.
It's really helpful if you have your original installation instructions to do this.
To order Panasonic parts see http://www.pasc.panasonic.com/epartr ; To download a Panasonic manual see
http://service.us.panasonic.com/operman ; to find an authorized Panasonic servicer, see
http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 ; For FAQs, see http://service.us.panasonic.com/faq/faq.aspx
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Panasonic NN-H664 Microwave Oven
Microwave Ovens Logo
89 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
