Is it possible to tune Hd or Sd channels on the DMR-E85H. I can only tune in analogue stations
    Scholar:
  • 91 Answers
Unfortunately no, it is not possible to tune Hd / Sd channels on the Panasonic DMR-E85H, because it only has an analogue TV tuner.
For Sd, you could insert a 'digibox' between the RF aerial input and the DVD, but you won't be able to get Hd currently unless you subscribe to a cable or satellite provider.
Posted on Mar 17, 2008
Bought second hand, having no luck trying to tune (search for tv channels) is it because it'san analogue device?
Quite possible as to work in UK it needs to have a digital tuner if it doesn't it could be used as a monitor for one of the sat or freeview boxes if the TV has the required connection socket
Scart =SD only
Component = HD upto the resolution of the screen in analog
HDMI = HD in digital signal unlikely on your panel
May 02, 2016 | Televison & Video
How do you re-tune the panasonic DMR E85H DVD Recorder. I have done exactly as it says in the manual and still it does not find any channels? Is it digital?
The tuner in the DMR-58H is a NTSC tuner (analog). Unless you have a low power station in your area, you will need a digital-to-analog converter box to record OTA stations. It can record analog cable without a box as well. (Digital cable will require a box.)
The manual for the DMR-E85H is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRE85H.pdf .
I hope this helps.
(at least in my area there is only one station broadcasting an analog signal; it is a low-power transmitter and thus wasn't required to upgrade to digital with the rest of the stations.)
Mar 27, 2012 | Panasonic DMR-E85H DVD Recorder
Will the Panasonic DMR-E30 DVD Recorder replace my STB to receive the digital free to air stations on my tv?
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
Oct 06, 2011 | Panasonic DMR-E30 DVD Recorder
My problem is I have a dvd player DMR-ES 15 I live in australia is it possible to tune in the new tv stations example seven 2
It is not possible to tune in 7two, channel 11, GO! or similar digital channels with this model DVD recorder, as its tuner would most likely be analogue only. You would either need to upgrade to a model with a digital tuner built in, or purchase an external set top box, capable of SD and HD digital reception, and connect its AV outputs to the respective inputs of the recorder, in order to record the channels you want.
However, being in OZ, those digital channels are available as free to air - all you would need is the appropriate receiver to enjoy them. I recommend a set top box which offers HD as well as SD.
May 05, 2011 | Panasonic DMRES15 DVD Recorder
When connected to the Panasonic DVD player I get a message when on One HD and any channel above that - "Unable to decode HD". How can I connect to these channels through the player?
You can't, without an external HD set top box connected via the recorder's inputs. HD is not a standard digital tuner format for this or any model Panasonic DVD recorder that I am aware of. Panasonic do not offer a way for the user/owner to skip the HD channels (which cannot be decoded) in these units. You can only skip analogue channels in VCRs/DVD recorders (which feature an integrated SD digital/analogue tuning system) - stupid really. It just means you need a separate box to get all the available HD channels through the unit.
Yes, 7mate (channel 73) is HD (but it isn't specified on their website or in the EPG) as is Gem ( channel 90) and of course One HD.
I assume your machine has a built in SD digital tuner.
Apr 25, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Search ResultsI have a Panasonic DVD REcorder Model No. DMR-ES30V itwill not find any channels
Assuming the antenna is connected, and you still receive analogue broadcasts in your area, this machine should 'find' channels fine. Because this combo does not feature a DVB supported SD digital tuner (unlike the DMR-EZ series which does), it is possible that the analogue tuner (or its associated circuit) is faulty (the best way to determine whether your combo has a problem or if you have no analogue channels in it is to check your TV - if that still has analogue channels, and those are OK, then it is the combo's tuner which is the problem).
The problem with this circuit is the abundance of surface-mounted components on the copper side of the board as well as standard ones on the other side (particularly in the power supply as well as the tuner). When these tiny parts fail, it is almost impossible to replace these individually, as they are glued and soldered to the tracks; manufacturers nowadays lean toward complete board/chassis/module replacement rather than indivdidual parts. It is also time-consuming for a workshop to trace the sources of the fault within these components; so the labour cost increases accordingly, and the parts are not cheap, hence the board replacement scenario.
My guess is one or more surface-mount ICs and/or surface-mount transistors to the IF/RF tuning module has developed an internal short which will mean a workshop repair.
This may not be economical for a DVD/VCR combo with no digital tuner as the unit is over 5 years old.
Here's what I recommend: with the advent of digital broadcasts, the cheaper option is to buy a digital set-top box (SD or HD or both if you can get it - any brand with standard AV/RCA sockets) - connect the outputs of the box to the inputs of the combo (assuming there is no macrovision by the channels from the STB allowing some taping/recording occasionally), select the input 'function' on the DMR-ES30V ('INPUT SELECT' is not a channel and does not use the tuner; it uses a separate control circuit as part of the video IF stage), and this should be OK. You can try this, and avoid the workshop completely this time.
It's messy, but a lot cheaper and simpler, since your DVD and VCR part appear to be OK. You should not need to replace the combo at this stage. Analogue broadcasts are gradually being phased out. I hope this helps a tiny bit.
Mar 03, 2011 | Panasonic DMRES30V DVD Recorder/VCR Combo
I cannot get the new digital channels throught my Panasonic DMR-EX87, that have become available of late, (GEM, 7MATE and ABC News24, I am in Australia). I have performed a system update and...
The tuner in this DVD recorder is a DVB-T SD tuner; it will also tune in the analog signals if you have any analog stations in the area. You will need a separate HD tuner (set-top box) to provide the HD content. I'm not sure if you can record from a set-top box with the recorder set to Line In or Input. The only input jacks are the A/V (composite) jacks.
I wish that I had better news.
Dec 03, 2010 | Televison & Video
My Panasonic DMR-E85H DVD Recorder's hard drive has failed, can I replace it with one from the computer store?
yes thy are usually just common 2.5 standard drives.
dont exceed the storage capcity without checking the unit can address that value via its cmos.
Please rate my help ++++Thanks for using FIXYA
May 13, 2010 | Panasonic DMR-E85H DVD Recorder
DMR-E85h
That's frustrating huh! I finally found someone at the cable company that knew somthing.. I think it's channel 95 (might be 94), if you tune to that channel, sometimes it get's it immediately, other times it needs some time to download it. But make sure you're tuning to that channel in your line up. In the setup mode you can specify it if it doesn't do it automatically. (just spend some time in setup and you'll see what I mean)
Nov 14, 2007 | Panasonic DMR-E85H DVD Recorder
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
