Question about Mercury P4VM800M7 Motherboard
System upgrading i want to upgrade my memory but this motherboard seems to reject most of the available memories in the market.Please advice on the specific memory specification to use and the maximum memory i can insert on each slots on the motherboard.
    Genius:
  • 1,226 Answers
Hello!
I think your memory specs is DDR 400 nonECC.
Maximum-is 2GIG
please refer to this site for more info. http://www.memoryx.net/p4vm800m7.html
may this help, melnavz
Posted on Mar 17, 2008
  • Emelio Navaja
    Emelio Navaja Mar 17, 2008
    YOu can insert 1Gig per slots ..If you use 512, then you have to buy 2-512mb, it should be pair or else use only one.
I want to upgrade the graphics card on my acer aspire m3400 but can not locate the card on the motherboard
That's because the video is integrated into the motherboard. This PC supports HDMI... what exactly are you trying to 'upgrade'? If the on-board video is not performing as you want, from what you can see here, you may only need to upgrade RAM on your MB:
http://support.acer.com/acerpanam/desktop/2010/acer/Aspire/AspireM3400/AspireM3400sp2.shtml
#4 at the bottom of the page:
Shared system memory may be allocated to support integrated graphics, depending on system memory size and other factors. Actual system memory available to the operating system will be reduced by the amount of dedicated and shared system memory utilized by the graphics solution and resources required by the operating environment.
Jan 05, 2011 | Acer Aspire M3400 PC Desktop
Need to find the right memory ram to upgrade to 1gig as i only have 256 stick in it.i need to know the right specs and module number
Since you're planning to upgrade the RAM of your computer here are the 3 different type of RAM that you can use for this motherboard.
400MHz(PC2-3200)
533MHz(PC2-4200)
667MHz(PC2-5300)
Sep 30, 2010 | Foxconn 6627MA-RS2H Motherboard
I need changes my memory 2 pcs @ 1GB DDR1 PC3200 with 2 pcs @ 2GB DDR2 PC6400 in Asus P5VDC-MX Motherboard. please advice. Thank you
Number of Memory Slots: 2×184pin + 2×240pin
Memory Standard: DDR 400/DDR2 533
Maximum Memory Supported:2GB
PC6400(DDR2 800) is not supported by your motherboard. Also max memory is 2GB. PC4200 is the fastest memory you can install. There might be a BIOS update available from ASUS website to increase the speed but you would have to check the site.
Dec 01, 2009 | ASUS P5VDC-MX Motherboard
My dell power light was off one morn,but my
Seems to be a Memory or a Motherboard failure. Make sure the memory you upgraded are the ones which are compatible to the system.
The compatible memory modules for your system are:
DIMM, 128MB, DDR2, 400M, 16X64, 8, 240pins
DIMM, 256MB, DDR2, 400M, 32X64, 8, 240pins
DIMM, 512MB, DDR2, 400M, 64X64, 8, 240pins
DIMM, 1G, DDR2, 400M, 128X64, 8, 240pins
The power light not turning on can be the Front bezel issue and not a system/motherboard failure. Please revert for any more issues.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
Memory upgrade HP Pavilion DV6304 Entertainment PC
yes it can be upgrade for 4GB for genuine HP memory. because hp exclusively use hp memory. all Hp pcs uses genuine hp memory.
Jun 07, 2009 | HP Pavilion dv6000z Notebook
Memory upgrade, download upgrade to run 400
According to the specs of this motherboard, it only supports 333, 266 and 200 MHz DDR SDRAM. It does not support 400 MHz DDR SDRAM.
This motherboard has only 2 memory slots, each can accommodate a 1 GB memory module. Higher capacity memory modules are not supported by this motherboard.
No BIOS upgrade is available to provide support for 400 MHz DDR SDRAM memory modules.
Jun 04, 2009 | Intel D845GVSR Motherboard
Upgrading memory card from 512mb to higher memory capacity.
We actually need to know what your motherboard is. You or let us check if your motherboard can support that memory or not.
Please ask if more help needed
Apr 03, 2009 | Intel Pentium 4 2.4GHz 533MHZ 478pin 512K...
Memory upgrade
yes you are
take your information to your pc shop and explain what you want to do.
They will then direct you in what type of memory and how much memory your system can take.
( A smaller pc repair shop will give you better advice and a better price then a major shop.)
Please don't forget to rate me
Feb 13, 2009 | MSI KM4M-V SOCKET-A WITH VIA KM400 CHIPSET...
I want to upgrade to a new video card
You can put new Video card accordingly. Just buy an good Video card which have inbuilt memory and that support your operating system. There are loads of Video card available in the market.
Dec 26, 2008 | Gateway GX7018E PC Desktop
Mercury P4VM800M7 Motherboard Logo
35 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
