Question about Nokia 6070 Cellular Phone
No signal hi!, my phone is lossing its signal. when i remove my SIM card and insert another new SIM then after I insert again my SIM the signal was lost can u help me this?
  • 85 Answers
First u make ur phone>network>settinge to atomatic it works if not use dummy sim of ur number it will solve ur problem
Posted on Mar 18, 2008
SOURCE:
Why I don't have network signal on my nokia 6600?
If you are not getting any network from your phone it my be be due to:* sim card issues* network / outage issues* phone issues
SIM Card issues:1. turn off mobile phone2. remove battery3. remove SIM card and memory card4. clean the SIM card from any dirt or dust5. wait for 2 minutes then plug back battery6. insert memory card and SIM card properly7. turn on mobile phone8. check if you will be provided with a signal from the upper right corner of your phone's screen. if not, try a different SIM card.
Outage:1. call your service provider and confirm if there are outages in the area or outages from the BTS where your SIM card is registered.
Phone Issues:1. if the phone is open line, try to enter a different SIM card2. try to insert the SIM card into a different phone, check if it will be provided with a signal3. if the second phone still dont get any signal and your service provider stated that there is no outage that may affect signal issues from your phone, check it from them if your sim card is still active.4. last resort is asking for a SIM replacement with the same phone number
Dec 11, 2011 | Nokia 6600
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
Whenever i get my sim card on my samsung e1080t celphone and inserted another sim card it instantly losses its signal.how do i fix this?
Your phone must be unlocked before you can use another SIM card. You can contact your carrier (most of the time) and get your unlock code, just supply them with your handset's IMEI number.
Jan 22, 2011 | Samsung E1080 Black OPTUS Cell Phone
My samsung mobile says insert sim card and SOS CALLS ONLY
hi,
here are reasons:
1) your phone did not detect your sim card.
2) you forget to insert the sim card.
3) the sim card you put in is defective or not properly inserted.
4) defective sim card terminal or slot inside.
for problem no. 1, 2, and 3, try removing your sim card and try inserting it again in correct and secure way.
for problem no. 4, have it repaired to service center.
Hope I helped you.
Don't forget to rate me OK! Thanks...
Rgrds,
John
Jan 05, 2011 | O2 Samsung SGH-E250 Cellular Phone
Always show the message 'insert sim card', When I refitted the SIM and turned back on, I had no network coverage. it always again n again n again..
Hi,when a phone does that, it means that the memmory of the phone is malfunction and it needs to be restored..
To be able to restore back the phone memory, you will need to flash the phone memory.
The links below will give you a guide line on how to flash the phone memory .
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
May 25, 2010 | Sony Ericsson K530i Cellular Phone
I've got "Insert USIM Card" mesage on my LG Ku380, please help me to solve this trouble
Causes:
~Sim Card Not properly Inserted
~Sim Card has Expired(in some countries sim card expires)
~The area where you Insert the sim card maybe damaged
Solution
~Remove sim card and Insert it again
~Buy new Sim Card
~If your still under warranty bring it to the nearest LG center, if not look for a certified cell repair shop
Jan 31, 2010 | Lgic Release LG KU380 3G Slider Phone
New samsung b2100, can't make calls phone says emergency call only!!
did you insert a sim card into the phone?
If the sim card is already inserted, then it must be a network problem.
Its either the phone network is bad or your phone service provider does have a limited service at the moment.
Switch of the phone, remove the battery and sim card, put them back into the phone and try again.
If the problem still persists, maybe you should call your phone service provider.
Best wishes.
Jan 12, 2010 | Samsung B2100 Cell Phone
Nokia 6070 Cellular Phone Logo
94 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
