Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
We just set up our 37 in sharp and get no picture
The first screen (select Language) came on but then the screen went blank. Every time we turn on the power it shows the input that the tv is on but the screen goes blank after 1 second. I pluged the cable directly and I get channel 2 picture and sound for 1 second then the screen goes blank but the sound continues. Any ideas?
If I shine a flashlight on the screen you can see a faint image on the screen.
  • jeano007 Mar 18, 2008
    Thanks! We are certianly exchanging it!
    Scholar:
  • 21 Answers
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
  • 4,234 Answers
If this is a new set, return it for an exchange. This one sounds like an LCD set which uses a "back light". This back light is not working. This is a warranty repair or exchange.
Dan
Posted on Mar 17, 2008
Good sound no picture
Check whether you have pressed the TV/AV button on the remote control.
Apr 03, 2013 | Toshiba 37HL67 37 in. LCD HDTV
I recently fixed the blinking green light problem following advice here. Now, about a week later, when I turn on the tv, I get image for a few seconds and then the screen goes blank/dark. Green light...
i have the same problem. i just replace the power board because of the "green blinking" light. now, light stays green, picture comes on for a few seconds, then blank....
did you fix your problem.
Aug 31, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp aquos display comes on for a few seconds then blank screen
I have the same problem with my 37" HP which is the same as Sharp Aquos, it's bad backlight inverter boards, the screen comes on for a second then nothing, no menu, no channel change indicator then turn it off and you hear the clicking of the power supply about 10 seconds after.
Jan 01, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Language setup
After trying on my own, I went back into setting by scrolling along until a picto gram - with what appears to be a machine bolt is highlighted and then pressed SET - next the screen shows a bunch of chinese words (these are the different languages) then I scrolled down to the last one - until its highlighted, - this is the english one - press the set button on the side of the frame, this will bring you back to the english menu.
Dec 26, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Picture size
This setup can be found in your manual that came with the tv on page 38
you may also download it at the following address for free.
http://media.onecall.com/Image_Products/Sharp/LC_GD6UManual.pdf
Digital Setup
This setting allows you to set the image of Digital
broadcasting.
Video Setup
You can adjust the settings for Digital image.
Screen Size
Set the format of image of Digital broadcasting.
1 Press MENU and the MENU screen displays.
2 Press < > to select “Digital Setup”.
3 Press ^ v to select “Video Setup”, and then
press ENTER.
4 Press ^ v to select “Screen Size”, and then
press ENTER.
Press < > to select “Manual” or “Auto”.
Manual is default auto is optional
since all tv channels do not broadcast in the same definition auto would be recommended
Selected item Description
Manual
Broadcasts in formats other than
480i will be converted and
displayed in the 1080i format.
With 480i broadcasts you can
change the screen size to the
size of your choice.
Auto.
All broadcasts will be converted
and displayed in the 1080i
format.
Nov 27, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Text
Then you have the settings wrong, select the picture settings menu and choose between 4:3 or 16:9 ratio depending on your programme.
Sep 15, 2008 | Sharp LC37P55E 37 in. LCD Television
Blank Screen No Audio
Ur main video backlight board is dead,must be replace.Try this website,Shopjimmy.com buy the board for $163,replaced it ur tv will work again.
Feb 09, 2008 | Sharp LC37SH20U 37 in. LCD Television
Language Selection
I had that happen. I found out that I had the VCR turned on. So I turned that off and The language select went away.
I was connected from satellite to VCR then TV.
Nov 14, 2007 | RCA HD52W59 HDTV Projection Television
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
321 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
