Question about Sony PlayStation Portable (PSP) Console
No screen just momentary green light
Green light on 1 sec no screen, tried charging and using A/C no luck. How much for soln and how reliable
  • 52 Answers
Maybe the psp is bricked or maybe the battery and the ac is tottaly dead. if its bricked, contact me for instructions on how to fix this, but first try another ac adapter
Posted on Mar 28, 2008
Kindle fire won't turn on - even after full charge
Press power and volume+ button together until reset screen appears!
Jan 17, 2015 | Tablets & eReaders
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
Kindle will not turn on
Try pressing and holding the power button for 20 sec. This should give you the reboot screen. You may have to press the power button normally one more time.
If that does not work, try charging, with AC adapter or USB port. The yellow charge light at the base should be on. Charge until this is green.
Apr 14, 2012 | Amazon Kindle 3G
I have a toshiba laptop satellite L-300 that won't turn on. I tried unplugging AC and remove the battery and hold the power button for 30 sec. and plugged the AC back, i can see the green light at the...
THE BATTERY LIFE TIMED OUT.TRY IT ON NEW BATTERY FOR TURNING ON THE SYSTEM.THE CHARGING ADAPTER MAY BR ALSO A PROBLEM TRY TO CHECK IT AC VOLTAGE LEVELS .
Sep 03, 2011 | Computers & Internet
Lenovo 3000 n200 0769AMU press power on switch green light on after about 1 sec screen still black no HD light fan running
Welcome to Fixya
Try to drain the electrostatic charge of the motherboard that usually cause this issue. I wrote a tip on how to do the power drain. Try to plug in external monitor on the VGA port and see if you are getting display using external monitor. If you are getting display using external monitor then the problem would be the laptop LCD. If you are getting the same black screen using external monitor then the problem is already the motherboard.
Thank you for using Fixya!
Mar 19, 2011 | Lenovo 3000 N200 0769 Intel Celeron 530...
Green light goes out after 10 sec no screen
1. Check battery - try recharging it overnight
2. Check integrity of AC charger if it still working properly. Or you can try charging the psp overnight using USB charger.
Apr 05, 2010 | Sony PlayStation Portable (PSP) Console
NAVIGON 7100 WON'T TURN ON
your battery is gone requires new one.
Aug 20, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Wont charge or turn on
not sure how long you have had this, but if the unit was completely turned off or battery completely dead, you have to hold the power button for about 15 seconds for the 3000t to start up...assuming the charge light at the top right is orange (that means its charging) no light means its not charging, green light means fully charged. if there is no power light on at the top right of unit, either the charger is bad or the port on the board is bad (which i do have) good luck and hope this helps. bill
Jul 05, 2009 | Magellan RoadMate 3000T GPS Receiver
Ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Nov 17, 2007 | Sony PlayStation® 3 (60 GB) Console
Battery wont charge,when plugged in phone lights up for 5 secs and screen fades Away
dear, your phone is charging but you are stuck in bootloader mode, you have to update your rom
Jul 23, 2007 | Orange SPV C500 Pocket PC
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
