Question about Refrigerators
Defrost timer hi, came across a fisher and paykel fridge, all completely iced up and was restricting evap fan, when defrosted evap fan ran fine and had continuity through the heating element. however when i turned defrost timer around so it clicked into defrost i was not geting any voltage to the element. and then after about 5 to 10mins or so the defrost cut out and refrigeration began again. would u suggest that the defrost timer is stuffed? would a defrost termination t/sat have caused it to start refrigerating again? i wasnt sure how long they normally stay on defrost and i couldnt read the wiring diagram on it as it was all ripped. cheers
    Sergeant:
  • 248 Answers
Sounds as if it is faulty but first try turning the power off / defrost / de-ice then try again.
Posted on Apr 09, 2017
zeusfaber
  • 247 Answers
SOURCE: evaporator fan jams with ice buildup from drain
Could be that, or it could be the temperature sensor on the evaporator - if that goes, then as soon as the freezer starts a defrost cycle, it will think it's got the evaporator hot enough and will start cooling again.
Suggest you let the freezer thaw out then, with a voltmeter connected across the terminals on the board which connect to the sensor, turn the freezer on and see if the sensor reacts sensibly to the evaporator cooling down. It's usually done with a thermistor, but just for the moment, I can't remember whether it's usually a PTC or an NTC.
That way, if it is the sensor, you'll be spared the expense of replacing a serviceable pcb.
A.
Posted on Apr 13, 2008
  • 1073 Answers
SOURCE: evaporator fan blade jams in ice buildup
check the defrost bimatal or defrost thermanstat it will be located on the evaperator suction line (large line) it should read continuity with the ref cold if it showes continuity then the defrost timer is the problem
  • 958 Answers
SOURCE: Defrost heater wont heat up
so you seems to have done your homework. all the inputs are great.
you said you have 206 volts at the heater connection prior to connecting the heater.
and would become zero once the heater is connected.
so you have a loose connection from the timer to the defrost thermostat then to the heater.
does the defrost thermostat you are talking about is the same as the bi-metal that we used to refer in our technical language.( it is the part that would open up as the temperature inside the evaporator rises to a certain level.)
because if you are referring to the fridge thermostat which controls the compressor. ( this is also 0 ohm when closed), then the problem could be in your bi-metal.
this is the part in between the timer and the defrost heater.
it terminates the power once the temperature of the evaporator coil is about 5 degrees Celsius.
here's what you can do.
run the fridge for a day ( so that we would be sure that the bi-metal is close) then put the heater in place, turn the timer to heating mode by turning it slowly.
then place the test leads across the bi-metal, if you can measure 220 volts then that is the problem.
it is not shorting out even with a freezing temperature. you can further test the system by putting a jumper wire between the bi-metal and you heater should be heating up now.
tnx 4 using fixya,
drcool
Posted on Oct 31, 2008
woodchuck789
  • 4070 Answers
SOURCE: Viking refrigerator with bottom freezer always running
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on Jul 05, 2009
SOURCE: measurement of defrost heater elemnt resistance in E 442B
yes, should be 165
Posted on Aug 06, 2009
Fisher and Paykell E522B icing
The thermistor sets the defrost cycle. Always go with the cheapest solution first but also ohm out your heater that could be the issue also.
Apr 13, 2013 | Fisher and Paykel Active Smart E522B...
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
Hi, I have a Fisher and Paykel E402B Fridge/Freezer. It has not been working properly for a couple of months.. It does not cool/freeze properly. Through investigation I discovered that the coils and fan...
the defrost heater or thermostat located on the evaporator coil thats icing up isnt defrosting due to a bad heater or thermostat,or it can be the defrost timer that powers these other 2 parts
Jun 21, 2011 | Fisher and Paykel Refrigerators
The fridge alarm will not stop. The fridge compartment is not cold and the freezer is just freezing. Since the problem started, have the fridge turned off for 3 days. Defrosted the freezer, turned it...
this alarm is activate if the temp. of the fridge rises and because the freezer section is full of ice form thats why affect the circulation of cold air. try to check the defrost timer if yuor unit have or heater if working if dont have defrost timer or heater try to lessen the setting of your themostat to cut of unit after reaching desired temp. or conduct weekly defrost manually.
Feb 12, 2011 | Fisher and Paykel Active Smart E522B...
Hi There My Parents have a Fisher & Paykel (E331T) the Freezer is working fine, but the fridge where the dairy products sit don't seem to be freezing at all im not sure if there suppose to be a fan...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Fisher and Paykel Active Smart® E522BR...
THE TOP PART (FRIDGE) IS NOT COOLING
Your defrost system may be out. There are 3 parts, the heaters, t-stat and timer. Hope this helps! :>)!
Aug 14, 2009 | Fisher and Paykel Active Smart E522B...
Freezer works fine but fridge has lost its temperature.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 02, 2009 | Refrigerators
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
