Question about Toshiba Satellite Pro A200-EZ2204X Notebook
Toshiba satellite pro m70 power problem
I have a toshiba satellite pro m70 laptop.there was no power in laptop.i opened it & take out the mother board but when i plugged in the ac power there is little noise from moherboard & there is no power.please help me.
  • Anonymous Apr 16, 2008
    my Toshiba Satellite M70, was kept on charger for few days as I forget to take it out. I tried to start it. it was not starting , or even there is no power indication when adapter is plugged. sevice men tolled me that the motherboard is damaged becouse of I kept on charge for severel days and it has to be replaced, costing ~ $510.
    I wonder is there is no overcharge protection in charger circuit for Toshiba Laptops.? Is there any try possible before I replace the board?
    any body to help ?
  • Anonymous Dec 23, 2008
    same problem
Windows xp not instltion
Posted on Mar 22, 2008
Satelite m70-181 audio drivers
u must download it from microcoft .... create an account and downlod it :)
Dec 27, 2013 | Amstron Toshiba Satellite M70-181 Laptop...
My laptop (Toshiba Satellite Pro M70) freezes (a times, it gives a blue screen error) when I move it [or adjust its position]. Changed the Hard disk but the problem still persists.
There's no M70 model, so I'm assuming you're talking abut a Satellite Pro M10, M15 series laptop. If the slightest movement hangs it or causes BSOD, then my guess is ... well ... I'll let you have it: the weaknesses of this models are: (1) bad memory socket (the upper socket),or (2) bad sound card socket. The one that's easiest to access is the upper memory socket - remove the installed memory from that socket, and see if your machine will still hang or blue-screen. I don't know if anyone still fixes these sockets (I do), but you can get around it by installing a larger capacity memory into the lower socket and skipping the upper socket altogether.
Aug 04, 2010 | Toshiba Satellite Pro M15-S405 Notebook
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba a215-s5837 problem, ac light only flashes
You may have a bad battery. Many times laptops will not work if the battery is faulty. The first step would be to replace the battery with a new one.
Second Step: If the battery is working, then you may have a faulty AC power supply. It may be enough power being brought to power up the LCD light, but not the computer.
Third Step: Yoru mother board circuitry could be bad in the sense that some circuits are broken or the power conduit is not supplying the power to the rest of the circuits on the board.
If you are not a professional and able to troubleshoot in this manner after testing the batter and AC power supply, then I would suggest taking the laptop to a store for them to test the circuitry flow of the mother board.
Dec 30, 2009 | Toshiba Satellite A215-S5837 Notebook
Ac adapter light is solid green, but when plugged into laptop...
the most likely reason is a systemboard problem (the ac plugin port cannot changed independently for notebooks)
Mar 23, 2009 | Toshiba Satellite A65-S126 Notebook
Loose power cord connection. Power goes off when moved
these laptops are known for the ac adapter to come loose from the mother board. ther are kits available to repair
Mar 14, 2009 | Toshiba Satellite M35X-S311 Notebook
I can not get any sound from my Toshiba Satalite pro M70 laptop.
please check your speakers, try to insert headphones and hear if u can hear any sound, try to install drivers
if u can hear the sound with headphones means there is a problem with ur internal speakers
Nov 24, 2008 | Toshiba Satellite A105 Notebook
No power in toshiba satellite pro m70
You need to check ur power sockets,
ur charger whether its working,
and test the battery,
also try to switch it on when there is no battery attached to it by just pluging the charger straight
Mar 17, 2008 | Toshiba Satellite Pro A200-EZ2204X...
TOshiba Laptop Not Charging or booting
check the power connector (on the back of you laptop - through whitch you feed power to the mother board) for lose or if it's broken
Oct 03, 2007 | Toshiba Satellite A60 Notebook
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
549 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
