Blue bright pixels on Samsung PS42Q7HD
Having the same issue - Have you fixed it?
  • mrdouble08 Oct 21, 2008
    Funny enough this reply just came today. I had my tv sent to an authorised Samsung dealer and the bright blue pixels still appear on the left hand side - just not as bad now.
    Going to get my plasma sent in AGAIN.. :O( I don't like watching tv on a 19inch LCD...
  • skobs33 Nov 07, 2008
    I have the same problem with my Samsung 42". I've had the TV for about a year and 8 months. It seems to be the same problem everybody else is having. What, if anything, can I do to fix the problem?
I had bright blue pixels on the left hand side of the screen only when the engineer came he said it was blue haze and an upgrade would sort it and it did. hope this helps
Posted on Oct 21, 2008
I have a NP470RSE-K01UB that has been upgraded to Windows 8.1 and I am having display brightness issues. I have all the Windows power settings set to max brightness regardless of whether the computer
Go to samsung website and go to support section. Download and install the samsung hotkey software. This should fix your hotkeys to turn brightness up and down.
Aug 11, 2014 | Samsung Computers & Internet
Picture pixelation
TV manufacturers know that a certain percentage of TV's will end up with dead pixels. I believe there is an app called UDPixel that can fix dead pixels on monitors and TV's. Google it.
Feb 05, 2014 | Sharp Aquos Televison & Video
Hi everyone. I'm having an issue with my samsung
sounds like you need to change the 'power options' in the 'control panel'.
start--> control panel -->power options
or just use windows search for 'power options'
there are settings where you can change how it acts when plugged in vs on battery. There are usually options to lock brightness.
Sep 23, 2017 | Samsung NP535U3C-A01UK 33.8 cm 13.3inch...
Losing pixels like crazy
Shure, you can have it fixed. I strongly suggest that you call around and check prices first. Samsung IS a quality brand. How many TENS OF THOUSANDS, if not more units do you think they make? Getting ONE bad, is a pretty god ratio. Sorry it had to be you that bought the bad one.
Apr 12, 2010 | Sony MHC-NX1 Shelf System
BLue spot in the middle of the screen
How big is the spot. That usually happens when a pixel or multiple pixels has the issue. Try logging into BIOS and see if you have the same issue. For more information on logging into BIOS, refer the instruction manual of your computer. If it is an issue with pixel it is a hardware issue. However manufacturer has its standard for replacing monitor on pixels issue. Dell replaces with 5 pixel faults, and i think with samsung is around 8 pexel. you would need to contact the monitor manfacturer
Dec 16, 2009 | Hitachi Televison & Video
I'm having problems with the Samsung 245BW. I bought the first one at Sam's Club and it developed some pixelation problems, i.e. blue and yellow horrizontal lines across the screen. I returned it to...
hi,
you can try this ,
check the monitor on the different wall outlet/ socket or check with different computer wheather it gives the same issue .. third option is check with both DVI and VGA ports differnetly.. please check wheather you are getting lines on the bios screen when u start the system because if you r getting lines on the BIOS screen (f1) then there is a issue with the monitor else issue with the video card ................try this ,if possible revert for the same issue
May 21, 2008 | Computers & Internet
SAMSUNG PLASMA
Do you mean that you have a bright blue dot on the screen that stays on all the time???
If this is correct, there is a fault in the display driver where a single pixel or a number of them are turned on all the time. This can be in the pixel driver device or circuit itself, or there may be a fault inside of the Plasma screen itself right at the lit pixel(s).
When you take the set in for service, they will be able to determine the exact fault. If it what I think it is, the service cost may not be feasible. I hope you have an extended warranty on this set!
Jerry G.
Apr 17, 2008 | Televison & Video
Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Jan 01, 2008 | Televison & Video
Blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Televison & Video Logo
346 people viewed this question
Top Televison & Video Experts
