Question about Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail
Troubleshooting Well all the parts are brand new ,that's why i am curious. Yesterday get stuck again whille i was watching a video in youtube. My system is : PS. Therrmaltake 750W MOTHERBOARD. GA-MA790FX-DQ6 Gigabyte. CPU. AMD Phenom 9500 2,2 GHZ. RAM. Kigston KHZ8500D2K2/2G HyprerX 2GB. (2x1GB) DualChannel DDR2 PC8500 1066MHZ. GRAPHIC CARD. Asus Ge-Forse 8600GTS 256MB. HD. Seagate 160GB Sata II I was thinking to take a CPU Cooler because I haven't changed it. You think this will help ?
    Scholar:
  • 178 Answers
How long have you had the system in that configuration? It doesn't seem to be a heat issue running around 45 degrees unless that is the idle temp. I need you to try something, when it shuts down, immediately restart the system in bios and look at the temp for the processor again. I solved my issue by taking a side off of my case and putting a small desk fan blowing directly into it. My idle temp went from 45 down to 27 degrees celcius. In a perfect world, the cooler a CPU runs, the better the system will respond. Find those temps readings for me, and let me know. Also, there may be a small monotoring program in your mobo set up disc to help monitor the temp while windows is running. And also, double check to make sure your processor fan is plugged into the correct spot on the mobo, mine is mislabeled, another issue I had found and corrected.
Posted on Mar 17, 2008
The Baratza Virtuoso electric Grinder is NOT grinding a fine coffee for espresso even in zero. It comes out very large, like for dripping coffee.
I own a Baratza Encore and had the very same issue. The Baratza website is your source for excellent info to replace the affected parts: I replaced the following after inspection. I suggest watching the video (disassemble your grinder and inspect what is broken)
link to troubleshooting:
https://www.baratza.com/troubleshooting/
After watching the following videos, I discovered that my adjustment ring/kit was broken (video 1) and plastic burr holder was broken (video 2).
https://www.youtube.com/watch?v=tvPmA2laBzM
https://www.youtube.com/watch?v=cGbdweJj40I
https://www.baratza.com/wp-content/uploads/2015/07/Baratza-Adjustment-Ring.pdf
1. adjustment kit ($5)(https://www.baratza.com/product/adjustment-kit/)
2. plastic burr holder ($4)
(https://www.baratza.com/product/burr-holder/)
Dec 28, 2017 | Baratza Coffee Makers & Espresso Machines
Gets stuck on "android" page when I turn it on.
  • How to fix an Android phone if it is stuck or frozen on ... www.smartmobilephonesolutions.com/content/android-stuck-on-samsung Sometimes Android phones get frozen or stuck on their loading screens. This isn't too common of an issue with Samsung phones running on the Android operating system ...
  • Android- Samsung S4 stuck on reboot page: [ Samsung Galaxy ... www.usoftsmartphone.com/t437669.html
    • 1 POST
    • FIRST POST: 2016-02-29
    2016-02-29 · UsoftTech :: WwW.UsoftTech.CoM :: Samsung S4 stuck on reboot page My Samsung S4, when turning it on, asked me for a password - I entered my password,
  • Android Tablet stuck on boot screen ! Bypass it in easy ... www.youtube.com/watch?v=HErn0-GcQqE
    • BY MY TABLET GURU
    • 5 MIN
    • 427K VIEWS
    2014-01-04 · Want to watch this again later? Sign in to add this video to a playlist. If your Android tablet is stuck on startup or boot screen, then bypass it using ...
  • Videos of stuck on android page bing.com/videos zClick to view 9:29HD Android tablet stuck on Android Logo Fix YouTube ",p:"https://www.youtube.com/watch?v=S1i58AUKn60",ns:"video",k:"5008",st:"http://tse2.mm.bing.net/th?id=OVP.V11b29ac3cbace951076efa80a90d359c&pid=15.1",stw:300,sth:168,du:"0:51",hd:"HD",vc:"188,000+ views",r:"720P",ha:"b3e2a9d9d6e95cc24bb8b87cd1bf38c9"}'>zClick to view 0:51HD Tablet stuck on Android introductory screen YouTube ",p:"https://www.youtube.com/watch?v=HErn0-GcQqE",ns:"video",k:"5008",st:"http://tse3.mm.bing.net/th?id=OVP.Vfe84da1cf9b5dae40aecc46e6d21fc17&pid=15.1",stw:300,sth:168,du:"4:36",hd:"HD",vc:"421,000+ views",r:"720P",ha:"0676f504c9fa13927a5854467b9fdc5a"}'>zClick to view 4:36HD Android Tablet stuck on boot screen ! Bypass it in easy steps. YouTube 2q==Click to view 3:50 How to Fix Stuck On Boot Start Screen Problem in Android ... YouTube See more videos of stuck on android page
  • Android Tablet Stuck at Boot Screen - Stack Exchange android.stackexchange.com/.../android-tablet-stuck-at-boot-screen Android Enthusiasts Stack Exchange is a question and answer site for enthusiasts and power users of the Android operating system. It's 100% free, no registration ...
  • Mar 04, 2016 | Tablets & eReaders
    Bosch dishwasher stuck on zero wont finish cycle
    Propably you have leak from the main pump impeller seal.This leak activate the floating probe that prevenge the end of the program.See the video below. It helped me to fix yesterday same problem.
    http://www.youtube.com/watch?v=DE7oYA5l3EQ
    http://www.youtube.com/watch?v=RLkMncM6JDE
    If you open the bottom of the dishwasher you can see the leak.It leaves calcium at the base of the pump.
    Sep 06, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
    Screen flicker toshiba
    Sounds like you need to think about buying another laptop. Or replacing the LCD screen. Search ebay or amazon for screens.
    Dec 03, 2012 | Computers & Internet
    I tried to watch youtube today but my video screen is black and the play button tool bar isn't even showing. Worked perfectly fine yesterday and was in excellent working order. How do I get back my...
    Hello jffkn8,
    You will need to clear the cache (temporary internet files) in your browser! I had this happen earlier this week with YouTube and that solve the problem instantly!
    If you need step-by-step help, please provide your browser and version!
    If this was helpful, please give me thumbs up!
    Jul 07, 2011 | YouTube Videos
    I just turned my treadmill on after not using it for about 3 months. Once I get started and get to about 2.5, it shuts off. I turned it off and restarted it and it happened again. I turned it off again...
    Most of the time its caused from not lubricating between the treadmill belt and deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
    Proceed watching this videos with mechanical adjustme and lubrication:
    http://www.youtube.com/watch?NR=1&v=USSgbsZbDLQ
    http://www.youtube.com/watch?v=hKbAqvuOBS0&feature=related
    http://www.youtube.com/watch?NR=1&v=KiEZDNe0F8Q
    http://www.youtube.com/watch?v=wjrVjYe2LYQ&feature=related
    http://www.youtube.com/watch?v=CuMjcPLYehw&feature=related
    http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
    http://www.youtube.com/watch?v=zXeHMWTcLUY&feature=related
    Of course you must shure after you did this,If there are some electrical and electronic problem. Motor+Controller Board and Transformer. Go to the 2nd Troubleshooting section:
    http://www.youtube.com/watch?v=qgb2TY3WCkg&feature=related
    http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
    http://www.youtube.com/watch?v=GPI6dFJCUA4
    http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
    http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
    http://www.fixya.com/support/r10786838-test_procedure_dc_motor
    http://www.youtube.com/watch?v=23ZgWaVEQjA
    http://www.youtube.com/watch?v=dxpOOPetVLo
    Apr 26, 2011 | Proform XP Weight Loss 620 Treadmill
    Yesterday when i go to youtube.com, it says Bad Browser
    goto internet options on browser and goto delete history and hit "delete all" then restore to default on advanced options
    Jan 28, 2009 | YouTube Videos
    Youtube stuck
    Try updating to the latest Adobe Flash and Shockwave players. These have a major impact on the performance of youtube videos. Try that and see if it helps at all. Also, make sure your browser is up to date.
    Sep 23, 2008 | YouTube Videos
    Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket AM2+ 3000 MHz Motherboard Retail Logo
    136 people viewed this question
    Top Gigabyte Computers & Internet Experts
    David
    David
    Alun Cox
    Tony
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
