Question about Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel smart drive 708 filter
Does the smart drive 708 have a filter? If so where is it located and can it be cleaned?
Thanks
Gaye
My machine swiches on but wont let it fill with water.
Any ideas?
adrian
Posted on Apr 18, 2010
  • paulus649 Dec 07, 2011
    check the water valve solenoid to see if it is still working
  • Angus Bratter Sep 02, 2013
    Hi, I'm having the same problem, where is the water valve solenoid?
    Sergeant:
  • 351 Answers
No there isnt try doing some hot washs to clean the machine.
Posted on Mar 19, 2008
I am getting a lot of lint on clothing is there a cleaning process with my smart drive pride 5.5 fisher & paykel washing machine
clean the lint filter in the machine
put any clothes that are likely to shed lint or are susceptible to collecting lint in a wash bag before putting in the machine
Oct 17, 2017 | Fisher Washing Machines
Fisher and Paaykel Smart Drive 708 not working once filled with water.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Mar 03, 2013 | Fisher and Paykel Washing Machines
Smart drive 708 will not drain at end of cycle
sounds like water pump may need looking at, if it is you can contact manufacturer with part no and either fix it yourself or get machine repair guy in
Jan 03, 2013 | Fisher and Paykel (IWL12)
How to clean pump from fisher & pkal smart drive 708
FIRST - remove plug from wall, then open lid and remove the rubber bungs that the front of the lid sits on, under them is 2 screws, remove them. Lift the complete upper plastic portion and rotate back against the wall. Remove the screw from inside the agitator and remove the agitator completly. Remove the bowl top cover by unclipping it from around the outer edge all the way round, note the spring position for refitting, lift out the bowl top cover and set aside. Remove bowl, can be tricky but it should lift right out. With the bowl removed, remove the large phillips screw from the plastic cover over the pump, with the screw removed, the pump cover will pull out (up) and the pump can be cleaned out.
Make sure that you clean out the channels that the water flows through around the pump impellor. refit the pump cover, ensure the rubber ring is in correct position, and secure with the screw. Reassemble in reverse order.
Test the pump for operation before doing a full load.
Mar 02, 2011 | Fisher and Paykel Fisher & Paykel Washer
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paykel smart drive 708 will not start
unplug the washer and wait 10 or 15 mins sometimes it takes time to reset the program
Aug 23, 2009 | Washing Machines
F & P Kelvinator Smart Drive 708 - Faulty power switch and cycles
I have a smart drive 708 that will turn on but won't fill, any suggestions?
May 25, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Power on washcycle won't start and light just blinks
Hi I have a GW708U Model. The lights on the display panel come on and then nothing happens when you hit the Start button. Any suggestions welcome.
Aug 18, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher & paykel slow to fill?
if its the cold water (most common) replace the valve remove the two screws on the top of the control panel then you will see the valve i think its the right one looking from the front.its an easy job .hope this helps.
Mar 20, 2008 | Washing Machines
Washing Machines Logo
1,519 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
