Repair or buy New.
Our twenty year old maytag died,need help to get it fixed motor seized,needs belt gasket and virtually all new insides,we live in Ricmond B.C.Canada and need agood qualified repairman to do the job can you help us out or should we buy a new one,we've told fix our old one.
Bob & Betty Clark
    President:
  • 1,294 Answers
It is better you look around for a new one................
Posted on Mar 17, 2008
SOURCE:
My boat motor has low compression @ number 1 cylinder how can I fix it
2 possibilities:
-1 Your head gasket is burned. Caution, some Mercury engines have no head gaskets. I could tell if I had your serial number.
-2 Your cylinder has seized. If it's the upper cylinder, you'll have also to check your cooling system! Look at your spark plug if you can't see some 'aluminum' deposit on it. Or, inspect the inside of that cylinder with an endoscope.
Such an old engine is mostly not worth a complete overhaul. So, in case of seizing, just hone that 1 cylinder and use a new piston with rings.
It's in any case better not to use that engine in this state.
Mar 06, 2015 | Seloc Mercury Outboard Repair Manual, 1965...
Agitator will not spin easily from pully below or
transmission out buy new washer cost to great to repair 15 year old washer
Feb 03, 2010 | Maytag LAT3600A Top Load Washer
Whirlpool Dryer needs a push on inside of drum to get started, by overriding the door closed switch. The electronic starter will not work, unless the door is open and it's given a push to engage...then I...
yes and some other parts that from long time of usage need to be replace as well.
If you want this machine to keep work for more years ...fix it :)
I have Appliances Repair company and I prefere to fix old machine and see them working for many years then new one that not last for long... what is your model # i tell you what parts to replace...
Jan 05, 2010 | Maytag Dryers
Blower fan is seized Kenmore 54501 Dehumidifier?
If the blower motor is siezed up, then you need to replace the motor.
You can have new bearings put in it, but by the time you get thru it will cost you about the same as a new motor and you won't have any warranty on the old motor, you will have at least a one year warranty on the new one.
Aug 09, 2009 | Kenmore 54501 Dehumidifier
Need to install new motor on Maytag PAVT454EWW
try going to partselect.com to find the parts they have a picture breakdown of your washer and you can buy the parts right there
Mar 10, 2009 | Maytag Performa PAV2200
Washer won't run
Well this means your motor is fried.
if it is more than 8 years old it is not worth putting good money into it. time to replace.
How old is the washer ?
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old washer
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your washer,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your washer is under warranty or less than four years old ,
paying for a repair makes sense.
Note that washers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your washer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new washer.
Data also shows that it doesn't pay to fix a less-expensive washer
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of washers you replace are likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not forget to give a rating before you sign off!
Dec 05, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
1997 maytag front load washer has smell of burning rubber in the chamber.
You said, after we did a wash, strong smell of rubber inside the wash chamber once it was opened...do we get a repair estimate or should we consider replacement at this point...who to call? a maytag repair place or any appliance repair shop?
How old is the model?
It may be only the belt is worn and or slipping.
If you need to repair ,our site has some good repair companies that are our sponsors.
Off to the right of the screen in our site is a window that you can type your zip code into and they
will find you service near you home.
Here is a report I just read that may help you evaluate fixing or buying new!
Repair or replace?
Note that washer is under warranty might require service from a factory-authorized technician;
given that today's models are quieter and have added features.
Data also shows that it doesn't pay to fix a less-expensive washers.
of a washer you replace is likely to end up in a landfill.
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Sep 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Old Maytag washer LA182 motor replacement
Neil,
I need to know if the motor came with a wiring diagram when it was purchased or did it just come by itself. You may have to learn how to read the wiring diagram that is stored inside the control panel.
Jun 09, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer wont spin. BUT, DOOR IS LOCKED. MAH 4000
Solution is right ...its your MCU Easy repair.
~Baloo
May 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
