Question about Asko D1876 Dishwasher
F2 FAULT AND ALL LIGHTS ARE FLASHING.
I HAVE A PROBLEM WITH A F2 FAULT ALL LIGHTS ARE FLASHING, OPEN DOOR CANT SEE ANY WATER IN MACHINE(SOUNDS LIKE IT IS STUCK BETWEEN CYCLES AND PUMP IS STILL RUNNING) PUT 2 LARGE SAUCEPANS OF WATER IN BOTTOM OF MACHINE AND IT EMPTIES,ALSO DISPENCER NOT OPENING AUTOMATICALLY AND THERE IS NO VISIBLE LIGHT ON THE START STOP BUTTON.
  • Anonymous Mar 23, 2014
    NO WATER IN THE BASE AT ALL
    Sergeant:
  • 351 Answers
F2 means water in the flood pan remove dishwasher from under bench and tip back the water will run onto the floor.then test the dishwasher while it is still out you can remove the rear panel were the hoses go through and check the drain hose for leaks also check the white plastic ring under the metal filter for cracks,they look like a dark line.as far as the dispenser the most common cause is the main board,remove door skin and control panel and check the back of the board for damaged tracks,you will also have to replace the wax motor(red) on the drying fan(if fitted)check the solenoid on the dispenser for open circut.hope this helps.Ian.
Posted on Mar 20, 2008
I want a special catalog, operation and maintenance
F1? Water supply/low water fill ?· Check water supply to machine
?· Replace water inlet valve "F2? Water level too high ?· Plugged/Bad water pump
?· Faulty water valve "F3? Pump problem Check pump trap and clean. "F4? Thermistor problem ?· Open thermistor, replace
?· Bad wiring to thermistor "F5? Fault in thermal cutout or heating pause fault. Selected temperature not reached in 90 minutes ?· Check heating element
?· Check thermostat "F6? Motor fault ?· Check wiring to motor
?· Replace motor if necessary "F7? Door lock release fault ?· Bent pull-rod for door latch
?· Bad door latch solenoid "00 00? Machine did not spin Check load for out of balance Redistribute load and restart
Sep 30, 2016 | Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
I have a adg7560/1. the cycle starts but ends after a few minutes. the light flashes four times
Run the dishwasher through a test mode
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
Should take about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled
Error codes
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
Read more: http://www.diynot.com/forums/viewtopic.php?t=200838#ixzz2zKhYFHxt
Apr 19, 2014 | Whirlpool Dishwashers
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
May 24, 2010 | Dishwashers
Machine will not fill the door locked sign
Sounds like could be fill solonoid valve faulty or water turned off..
Jan 23, 2010 | Hotpoint WMA54 Front Load Washer
Dishwasher not completing full cycle
Hi i too have the same problem matrix mx194 approx 4 yrs old.On near completion of cycle the 3 center lights out of the 4 on the inside of door flash and a ringing tone indicating a fault. When the door is open there is approx 1'' of water in base of machine and the inside is extremely hot and full of steam.
Can anyone please help
Nov 21, 2009 | Dishwashers
Washing machine fault
Usually indicates door is not closed properly.
If it is shut securely, and still does not work, then you could have a faulty door lock.
Another possibility is the control unit could be faulty.
Nov 29, 2008 | Indesit W 123 Front Load Washer
W1203
Front lower left corner has an access door.  Pry the access door open.  Inside you will find a yellow tab that will open the machine glass bubble door. Below the yellow tab is a cca. 2.5 inch screw-in plug.  Place a pan in front of the machine and unscrew to plug.  Water will drain out of the machine.  With the plug removed, tilt the machine forward past 45 degrees until all water has drained out.  This will reset the washer.  Insert the screw-in plug.
Apr 14, 2008 | Miele 11120301 W1203 Touchtronic Washer...
Asko Dishwasher F2 Fault
i have an asko washing machine that is displaying f2 how do i fix this problem myself without calling any one in
Jan 21, 2008 | Dishwashers
Open Questions:
See all Asko D1876 Dishwasher Questions
Asko D1876 Dishwasher Logo
514 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
