Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
What going on
Stater motor keep spinning evenythough the enginge already on
Bad switch or Solenoid. depending on the bike.
Posted on Mar 20, 2008
    Scholar:
  • 150 Answers
The starter motor doesn't spin until the starter gear engages the ring gear on the clutch basket. the starter gear doesn't engage unless you hit the start button the start button doesnt make the starter spin directly it is the "bendix" kicking the gear out to the ring gear that hots up the starter motor. so your problem is the gear is stuck engaged thats why the thing starts as soon as you turn the bike on because the gear is engaged and this is what hots up the starter. clear as mud? you might could clean and lub that part of the starter and avoid a rebuild or replacement
Posted on Apr 23, 2008
2010 frontier v6 stater spins but engind doens't turn
Either drive isn't engaging properly (faulty solenoid or wiring) or there is a "bald" patch on the ring gear.
If it will eventually start it's more likely to be a solenoid / wiring issue.
Feb 24, 2015 | 2010 Nissan Frontier
Part number of electric start gear on 247-88190 starter motor
Look for comments about Pinion Drive. If your starter gear sounds like it bangs into the Flywheel and then immediately just spins.
I t might be a $14 part ( 590644). Is it a Tecumseh Engine?
Feb 18, 2015 | Garden
Kohler diagram
only thing it can be now is charging stater is bad but dosnt make since its getting power somewhere has to be stater is charging check voltage at stater see if power there if is check relay behind dash see if power there then go to switch see power there this done while engine is running and battery unhooked if no power at switch replace it if motor wont start jump start at starter to get it going if wont start let me know well go from there
Sep 02, 2014 | Garden
Evinrude motor problems
The stater gear is thrown up by the quick spinning of the starter motor. It is on "ramps" that move it up. They can get corroded or gummed up. It should have a very light or dry lubricant on them.
Also if the motor is worn it may not accelerate with enough "snap"
If the battery is weak or the connections are corroded, you can get the same result. Hope this helps.
Jul 27, 2014 | Johnson Evinrude Starter-Outboard -92...
Citroen troubleshooting
well since the starter was only 2 months old i am betting its an ignition short. When u turn the key, the solenoid on the starter engages the bendix gear with the engines flywheel and then energizes the starter motor. And when u release the ignition the solenoid and the starter motor should de-energize. hope this helps you.
Mar 05, 2014 | Cars & Trucks
Stater problem 420 honda 4wheeler 2010
PULL THE STARTEWR AND SEE IF THE STARTER DRIVE OR STARTER BENDIX IS BAD IF YOU START THE MOTOR AND IT HANGS IT WILL CAUSE THIS PROBLEM GOOD LUCK
Jul 14, 2013 | Motorcycles
Hi i have 1995 honda vfr 750 cc it would start sometimes it wont it would just sound like grinding i have replace the selinoid stater motor was check at the dealer said is perfect working i have bought new...
If your starter motor always spins but the motor only cranks over intermittently, you have a bad starter clutch. Replace the large starter gear and the three rollers in the one way clutch and the motor should turn over every time you hit the starter button. Parts #3 & #14 . http://www.bikebandit.com/houseofmotorcycles/1995-honda-vfr750f-interceptor/o/m2786#sch7879
May 16, 2011 | Honda VF 750 S Motorcycles
When i turn the key on it sounds like the car is already started
That grinding noise is the starter motor gear not meshing with the flywheel gear most probably caused by a worn starter motor gear or weak solenoid inside the stater motor. You'll have to replace the starter motor to repair the car.
Nov 24, 2009 | 1999 Ford Taurus
1990 Volvo 249 DL Stater issue !
pull starter and clean, check stater solenoid, check all electrical connections
Sep 13, 2009 | 1990 Volvo 240
Lands Phones Logo
353 people viewed this question
Top Harley Davidson Lands Phones Experts
Gar
Gar
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
