My car amp works produces distorded noise . As I plug in the rca cables i noticed that if just the tip of the connector touches i get a good sound but if i insert the whole connector it becomes distorded what might be wrong with my amp?
    Scholar:
  • 54 Answers
You have a grounding issue.
The RCA inputs of the amp are many times NOT tied to chassis ( the chassis of the car ) ground.
Same goes for the RCA outputs of your head unit.
The speaker outputs of your amp SHOULD NOT EVER be tied to chassis ground.
  • make sure that no speaker wire from the amplifier is touching or attached to ground.
  • Make sure that your amplifier ground (GND )( of the 3 power inputs.....GND, +12V, Rem) is securely mounted to a bare metal spot on the frame. Best practice is to have the amp GND, and the head unit GND at the exact same physical point.
  • Make sure that your RCA cable shield ( not the center tip, but the part around it ) is not touching the chassis.
  • Make sure that you have not nicked the wire while installing it and are accidentally getting a connection to the frame of the car.
  • Make sure that the head unit is grounded properly.
  • IF for some reason you have an equalizer between the head unit and the amplifier, make sure it has its own switching power supply INSIDE the EQ.
Bad grounds are a pain to troubleshoot......best of luck....Rob
Posted on Mar 17, 2008
Loud noise from subs amp is grounded well
Check the output of the amplifier with the input connections disconnected. Does the sound go away??
If it does, then connect each input one at a time and see what happens. If the sound appears, then do the following:
The ground connection on RCA connectors don't always make a good electrical connection. This is the outside ring. If the RCA connector goes in easily, the the outside ring should be compressed slightly to garantee a snug fit. Do all of the RCA connectors, at the amplifier end and at the radio end.
It could be the way that the amplifier was installed. the ground lead should run directly to the battery NEGATIVE terminal. This will greatly reduce noise produced by other equipment.
Jan 31, 2015 | Car Audio & Video
Amp stopped playing riding down the road, power light turned off. came back on when i unplugged the rca's and cuts back off when i try to plug them back in.
Faulty RCA cables, Or worse possible solution is if your amp stopped playing when it was pumping at high volume, you may have blown the RCA connectors inside your head unit Or inside your amp. If possible try another known good working amp with the wires you already have, If same happens, try different RCA cables. If problem persists after trying these, Its your head unit RCA connecters or amp RCA connectors. To rule out your amp connectors, try your amp in a friends car if possible, to rule out your head unit, try another good known working amp in your car with the wiring you already have
Mar 03, 2011 | Kicker ZX300.1 Car Audio Amplifier
The amp from time to time gives a tone to the speakers even when the rca audio cords are not hooked to the amp the protect light isnt on and all the wires work properly i hooked different amp to the...
You are on the right track. It's not the amp, but it is the rca wires. When you have them plugged into the stereo, you can touch them together and it will make the same sounds you described also, though I don't recommend doing that! Rca wires can be weird sometimes but usually I replace them with new ones. Even a brand new set of cheap ones will do the same thing sometimes. The noise you here is causes by either a small short in the wiring, running the rca's to close to the power wire for the amp (or any other power wire for that matter), and sometimes you can buy a grounding kit for them that is fairly cheap that will help. Most of the time for me, it was just the connections, but replacing them basically took me through all these steps at once. Just remember, you still have a chance that your head unit is the cause by the connections getting old and wore out on the inside. Hope this helps!
Aug 05, 2010 | Hifonics BXI 1606D Car Audio Amplifier
I have a alpine mrp-m500 for about two years no problems at all. but one day it stops producing sound. i check all fuse on the whole system. is the a protect mode? and how do get it out of it?
If you have checked all the fuses.
Trace your ground wire that goes to the frame. It may be possible your ground is no longer grounded properly. You may just need to unhook the fuse from the battery, Unhook the ground wire from the chassis and restrip, put on a new connector, chisel off the paint around where the amp was grounded to and tighten it back down. Hook back up your fuse to the battery and check and see if it removes the protect light.
Also check to make sure your RCA cables aren't bad. If the RCA cables ground it'll put the amp into protect mode too. Basically just switch out the RCA cables for a good pair.
If the remote wire on the amp is touching the ground, it'll throw the protect light too. That's pretty much the extent, unless the amp has a short inside it.
Hope this helps!
Jul 26, 2010 | Alpine MRD-M500 Car Audio Amplifier
How do i check if my amp is still good?
first make sure that you have power check the red thick wire, and the remote wire with a voltmeter if its ok then disconect the rca plugs now get a pair of rca wires plug one end to the amp and touch the other end if it makes noise your amp is good ( please be very carefull as it will make a loud noise on the speakers when you touch the other end if the amp is good) good luck
Dec 16, 2009 | Car Audio & Video
Noise in my car amp.
sounds like you have a bad ground going to your rca's. try running a wire from ground to the shield of your rcas and see if the noise goes away.
Apr 19, 2009 | Rockford Fosgate Power 1050S Car Audio...
Audio won't play on DVD - but it will play for CDs
Hello, you can verify that your receiver is working or not. When you are playing a dvd unplug the audio RCA plugs (red and white) from the back of the Sony dvd player. Touch the tips of each of the RCA plugs with your fingertip. You will hear a buzz sound coming from the speaker associated with the plug if the receiver is working\ i.e. touch the red RCA plug tip and the right speaker will hum...touch the white tip and the left speaker will hum or buzz. This will not hurt your system or speaker. If you do not hear the hum turn the volume to 3 or so and wet your fingertip and tap the tip of the RCA connectors. You will hear "pops" coming from the respected channel. I believe your cd\dvd is at fault. Good Luck!
barneyluc
Oct 02, 2008 | Yamaha HTR-5440 Receiver
RCA Pre-Out Making Producing a Mumming and a Popping Sound.
the speakers hook to speaker wires not to any thing else no power no negative poles do you have a remote shut off switch connected to amp this would be important to cut off amp
when cut off amp if you still here the humming this can be an indicator of low power being produced by alternator alternators produce 14 anything below 12 would mean replacement of alternator
if alternator fine then you need to find new ground for amp and make sure you have a good ground for sterio this can be checked with a test light
to check a ground all you do is hook gator clip to power then touch test light end to ground on radio end light comes on got a good ground (make sure not to touch any other sterio wires just the ground wire while connected to power to check grounds)
if pulsing in test light on the ground means you have a bad ground
just disconnect move to better ground
check the amp ground the same way as decribed above
May 09, 2008 | Pioneer DEH-P3900MP CD Player
49 people viewed this question
 Grubhead
Grubhead
