Question about RCA DRC8060N DVD Recorder
RCA drc8052 frozen and won't do anything.
Was recording & it kept freezing when I would pause to fast forward dvr recordings thru commercials. It would get stuck on pause. Then it worked fine for almost an hour of pausing and ffwding now its stuck again. Help.
  • 2 more comments
  • Anonymous Sep 30, 2008
    hi, i have the same unit i got from a seller on ebay.its doing the same thing even not recording.did you get it fixed?
  • Anonymous Oct 25, 2008
    After I record for a while, if I stop, then it freezes on me. I have to unplug and then restart the recorder to use the same DVD. Any solution?
  • badproducts Oct 26, 2008
    Same prob. Recording football game, when I pause recording (dont want the commercials) it would freeze and lockup, saw a link on another website that posted an rca adress to correct the prob. but when I went there it said page no longer exist but it does have rca layou on the page.
  • Anonymous Dec 09, 2008
    i have same problem ,does anyone know what to do?
SOURCE:
SOURCE: rca drc8052 locked up at
i took off all connectors and put them back on.i believe its the circuit tape for the laser eye.bad design connector,barely fits in,very hard to put in,mine was at an angle. i used small angled needle nose pliers.its inside the loader.mine was a drc8052nc recorder, but might be for others.
Posted on Oct 12, 2008
SOURCE: drc8030n Motherboard
Thank you so much for sending me those parts, and an extra thanks for the extras. Which happens to be what I needed to fix my problem. You won't believe it... I got your well-packaged parts today. I soon replaced the Motherboard, no change, still the same HELLO... I was so deceived... Then, I decided to replace the Power Supply, just in case... IT WORKED!... (thanks for sending me a free power supply)... Looking at my power supply, I can see that on the printed circuit under those 3 diodes, near the transformer, is an area that seems to have overheated. I will test it and give you the results eventually, as well as the results and solution if I can fix the DVD burner. I'll use the extra fan you so generously gave me to cool the power supply, seems like it won't hurt. Though I have to place it right, or it'll make the problem worse... Seems like anything wrong with this DVR and all it'll do is display HELLO... I've heard of a bad DVD Burner, a bad Motherboard and now a bad Power Supply that causes the HELLO... Thank you so very much GSAN, you did it... I recommend you to everyone out there for your fairness, kindness and devotion. We should call you Mr. FixYa!...
Posted on Nov 13, 2008
  • 3 Answers
SOURCE: When turned on stays stuck in Hello mode and nothing works.
You cant solve this problem . This is internal problem . So you first contact the experienced mechanic. do first
Posted on Jun 02, 2009
sodeep
  • 3267 Answers
SOURCE: RCA drc8052 instruction manual
You can buy the manual from this link: http://www.retrevo.com/s/RCA-DRC8052N-DVD-Players-review-manual/id/2811bh446/t/1-2/
or better you register your product at: http://support.rcaaudiovideo.com/manual.aspx?product=234
and download it free or go to safemanuals.com, link:http://safemanuals.com/zearchres_3177.php and download ur manual......................................sodeep
Posted on Jun 25, 2009
3764alan
  • 127 Answers
SOURCE: MY RCA DRC 8320n DVD Recorder/VCR Combo will not
Yah, you're going to be taking that in for repair. I worked for couple of years at RCA / Sony / Panasonic / ... and 60 more names - service center. When a VHS Cassette loading mechanism doesn't work - it probably needs loading motor or loading gear, something repaired. At the cost of DVD and VHS combos these days I'd call it Not Worth Repair (NWR) out of the starting gate. At least $50 an hour, at least 2 hours ... that's beyond the cost of a new one.
Posted on Nov 28, 2009
I have a 3.2 IR dish network remote. How do I fast forward through commercials on DVR?
you can only fast forward recorded movies. Use the dvr button with the arroww that points to the right.
Feb 26, 2011 | DISH Network IR Remote Control
Skipping ahead when viewing recorded programs
It sounds liek your remote control button is sticking inside a bit.
To test it, have it playing, and hide the remote under a cushion so it can't possibly send a signal to the main unit.
Sometimes the rubber buttons need cleaning underneath, even though they don't appear to be stuck down at all.
Its also possible that the remote is actually just going faulty emitting fake signals. I have a HiFi that turns on and starts the radio all on its own (spooky!!!). I found its the remote occasionally sends a radio-on signal about once a week to the HiFi :)
I just hide the remote now unless i'm using the thing.
Apr 03, 2010 | Logitech Harmony 880 LCD Remote Control
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Directv DVR vs Tivo
I found the manual for that model online, and according to it, the "Live TV" button should function exactly the same way your old Tivo did.
If it's not working correctly, you may want to contact the manufacturer, assuming it's still under warranty.
Aug 06, 2008 | Hughes HDVR2 with 105 Hrs DirecTV DTV...
DVR won't play
I hae a Motorola 6412 that had this problem. I turned it off, then unplugged it for 30 seconds. After turning it on I had to wait 1-2 minutes before I could acces the DVR, but it work now.
Jun 11, 2008 | Arris DCT6200 DTV Receiver
Need diagram to connect Motorola DVR, Panasonic DMR-E recorder, A/V Receiver, and HDTV
Your not going to be able to connect in series (not sure if thats your goal) since your limited by the type of connections you can use. Your receiver is going to have to be switched depeneding on what source you want to listen too. DVR, DVD, etc. HDMI is going to important for your TV connection. Radio Shack has cheap HDMI cables.
So... connect HDMI from DVR to HDTV this will give you sound and picture to TV. Connect DVR optical or coaxial ( RCA if you dont care about surround) to Receiver to give you DVR sound thru Receiver input.
Connect DVD to receiver via optical/coaxial/rca for DVD sound thru receiver (again RCA is not recommended for surround).
Connect Component video to HDTV(or HDMI if TV has second HDMI input) to give you video from DVD.
Connect Yellow video or S-video from DVR to DVD recorder input to allow recording from DVR. Also connect red/white audio to (same) DVD input.
That should cover it.
Apr 09, 2008 | Arris DCT2608
DHG-HDD250 problems when recording
When I'm watching a recording program and recording a program I can't fast forward, pause, stop nothing works until the program that is recording stops.
I reset the machine, but it did not help.
Feb 26, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
Polaroid Will NOT edit out Commercials!
You need to post edit the recording;
First unprotect then do a split before the commercial
than split after, then recombine the parts without the ad.
Cumbersome, but it works
Feb 12, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Tivo pausing
Most likely your hard drive. You can replace it and not junk the unit.
Oct 05, 2007 | Philips DSR708 DirecTV DTV Receiver /...
RCA DRC8060N DVD Recorder Logo
112 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
