Question about ASUS P4VP-MX Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
Hi everybody,this is ramakanta from India.My motherboard is AsRock P4i45GV R5.0.Presently neither I am getting any beeps after opening the RAM nor any display.Only CPU fan is moving.I am not getting POST screen too Is there any body who can tell me where must be the problem??? no beeps and no display in monitor only fan is moving..Please, give us such as nice solution..
  • Anonymous Apr 24, 2008
    No beep,No Display on my monitor,only CPU heatsink fan is moving problem
    Guru:
  • 377 Answers
Dear reclane
theat sound is sign of memory needed to your motherboard, try using a brush to clean your memory, after that you can put your memory again
or you can try to clear cmos with short the jumper the right next battery cmos, short pin 2,3 and power on yor pc. after that put in normal position
the last try to change your power supply with a new
oke
i hope it can solved your problem
thx
cropp
Posted on Mar 17, 2008
  • 148 Answers
Try to clean your video card and ram using the eraser.
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 03, 2010 | Asrock P4I45GV R5 Motherboard
I have a m,b, asrock 845 presscot mothwer board cpu fan is running but not booting and not display .
are you getting any beeps. These can tell you what your problem is. Just google asrock beep codes
Aug 25, 2010 | Asrock 845GV (P4I45GV) Motherboard
CPU Heatsink is cool but fan runs fine no display
No beep or sound means Motherboard Defective, aside from Processors is OK, Memory is OK, and the rest!
Buy a new one not as the same Motherboard you use. ASROCK Motherboard are have a a problem when high temperature occur.
If i am helpful to you, please rate me.
Thank you.
Yboyandrei
Aug 29, 2009 | Asrock P4I45GV R5 Motherboard
No Beep sound during startup. Motherboard or Processor ?
ok
pull cmos cell for 15 minute then check so all settings of bios are reset.
Also Refix RAM memory reattach all connection to motherbord.
Jul 16, 2009 | Asrock P4I45GV R5 Motherboard
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
have you thought about changing the battery on the motherboard, also checking that the fan on the cpu is seated properly with enough heatsink paste as both these issues will stop the pc from booting
Oct 29, 2008 | Asrock K7S41GX Motherboard
hey
there might be problem with SMPS also. I mean there is one signal comming from SMPS - Power Good
if that singal is not comming then machine shows this kind of symtoms.
To check Power Good from SMPS -
Requirements ->
a) small wire/ pin
b) Multimeter
Procedure ->
1) Disconnect all power supplies going OUT from SMPS.
2) Locate the Orange Wire , Green Wire, Blackwire
3) Now insert small pin / wire into Black + Green wire (Make them SHORT) and provide power to SMPS --> SMPS will get started.
4) Now check the Multimeter rating for Orange wire --> it should not be less / more than 3.3 - 3.6 volts. --> If it is less / more then there is problem with your SMPS and you need to get it repaired.
5) In india it will take near about 100-150 Ruppes to repair SMPS.
alternate ->
You can replace your SMPS with other working SMPS (best option will be your friends system) and check whether same symptoms occurs or not.
Other Damedge -
If SMPS is working fine then there must be problem with FEW SMDs available on your motherboard. For this repairing in INDIA it should not cost your more than 600-700/-
May 29, 2008 | ASUS K8V-MX Motherboard
No display on monitor
Can be a problem with any of the components.
Do the power supply, cpu fan and disks start to spin after power up?
Does the PC speaker sounds a sequence of beeps? Can you identify a pattern, like 3 short beeps indicates a memory problem.
Keep posting so we can zoom in on the problem.
Dec 28, 2007 | Computers & Internet
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
ASUS P4VP-MX Motherboard Logo
317 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
