JVC Receiver-amplifier RX 884 VBK
The screen stop working,remote stop working and the sound from dvd doesn't work...
5 Suggested Answers
SOURCE: Does not respond to remote control
I have had the T743 for about three years now. The first unit which I got from the local shop was doing exactily like your described after couple of minutes use. Well, I took is back and got a new one covered by the warranty.
Unfortunately I never got any explanation to this problem from my local shop or anywhere else, so I guess the only way is to contact your local shop.
Posted on Dec 30, 2007
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
SOURCE: JVC RX-888V hook up to cable box - no video
There is some sort of setting you need to change on the JVC receiver. I had this same problem, and I read the manual and it solved it. You need to press and hold down a button to change the mode. Your unit probably says "TV Sound" right now. Once you press this button (not sure what button) like the manual says, the display should change to "DBS" and then it should work just fne.
Posted on Apr 08, 2009
CAYPIANAN
  • 227 Answers
SOURCE: The unit does not work
check the standby power supply first and then the main power supply.also check the output transistors and fuses your problem is in one of those points, normally the standby transformer goes bad, it is the small one right next to the big one.
good luck
Posted on May 22, 2009
I have a URC-9911B00 Oneforall remote, will it work with a JVC RX-7000V Audio/Visual Control Receiver?
The URC-9911B00 remote probably will work with RX-7000V receiver. Try code 0074. The remote was programmed in 2002 and the receiver was listed for sale Amazon in 1999.
I hope this helps.
Jan 27, 2017 | JVC Televison & Video
Why no coaxial fm connector on rx-884-v?
It's only no connector,like TV antenna socket. For coaxial antena cable, just plug it to 75 ohm and ground socket. No need jack/connector.
Aug 25, 2015 | JVC Rx-884v Theater Dolby Digital...
Can't get my center spkr.to work on my jvc rx 807v receiver
Make sure the speaker is good by connecting it to a known good working site. If speaker is good, make sure it is properly connected to center speaker terminals. Then if it is a surround receiver make sure that the sound mode is one where the middle channel works such as 5.1 DTS, etc. If the center channel still does not work then the problem lies with the decoder chip that is not working properly and sending the center channel info to that specific amplifier.
Mar 10, 2015 | JVC RX-807VTN Digital Surround System...
I have a jvc rx-518v amplifier with a burned out resistor on the imput board (r474) and diode (d474). They are severely overheated and the identifiers are gone, but the rest appears functioning. Any clue...
R474 should be a 18Ohm 2 watt metal oxide resistor part no. QRG022J-180AF
See page 2-9
and D474 is a zener diode part no. MTZ12JC see page 2-8.
The service manual can be downloaded from
JVC RX 518 VBK SM Service Manual free download schematics eeprom repair...
scroll down and select Get Manual link.
Aug 24, 2014 | Televison & Video
My jvc RX-5020 VBK IS NOT WORKING AT MAX VOLUME,ON SCREEN APPEARS OVERLOAD SOUND STOPS AND I HAVE TO TURN IT OFF AND TURN IT ON AGAIN ! WHAT IS GOING ON???
You must be using speakers with lower impedance than what is recommended. This causes the amplifier to over load at high volumes.The protection circuit shuts down the Amplifier to prevent further damage.
And please remember no amplifier is designed to run at full volume, same as a car speed - Even though the speedometer might show max: speed 200Miles per hour would you do it???
Jun 19, 2011 | Car Audio & Video
Mar 20, 2009 | JVC RX-888V Receiver
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
247 people viewed this question
 Grubhead
Grubhead
