My Printer is the Canon iP90, which has been extremely reliable but for some reason is now crumpling paper, the paper is not passing through the paper "printed" slot but is bunching up. Also the paper enters the pinter on a diagonal or so it seems, Also the roller seems sticky. Problem, if so,how do I clean it. Pjb Seattle
    Genius:
  • 3,587 Answers
Clean it with denatured alcohol and those tight cue tips(not the soft ones for your ears)..
Posted on Mar 17, 2008
SOURCE:
Canon ip90 will not take paper through the printer
I have had similar problems with Canon and Epson printers. Standard solutions are not earth shaking, but worth a try. Use paper heavier than 20 lb, get a roller cleaner paper from the manufacturer
and run it through to clean the rollers.
Jun 04, 2014 | Canon PIXMA iP90 Mobile Printer
Lexmark Prevail Pro705 printer jams each attempt to print. Reasonably new, Lexmark just replaced printhead and ink cartridges under warranty and printer gave better print results than when brand new. Joy...
Make sure your printer is updated. Please visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update on your computer. The update will make your printer more reliable and more efficient.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 13, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
My canon ip90 wont print anything
Good day!Kindly check if your printer is still running..check paper..inks..drivers...see if it is your default printer..
regards..
mastergani
Mar 29, 2010 | Canon PIXMA iP90 Mobile Printer
Canon ip90 has error message 1300- there is no paper jam- have tried to reset- no luck -help
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 03, 2010 | Canon PIXMA iP90 Mobile Printer
This is my 3d iP90 in 18 mo. w/same problem: not dragging paper
That is a fairly fragile printer, if you pack them in luggage they put other bags on top which bends the frame of the printer so that paper can't pass thru anymore. The only repair is to replace the entire print engine which costs more than a new printer.
Oct 09, 2009 | Canon PIXMA iP90 Mobile Printer
Canon IP1880-Paper jam
after you get all the crumples out
wipe down the rollers with alcohol to clean them and wait about 5 to 10 minutes before trying to print
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Office Equipment & Supplies
My Canon Pixma IP90 will not print. It pushes the paper
you going to take printer in for repair.or get a new one
Jul 18, 2009 | Canon PIXMA iP90 InkJet Printer
Canon ip90 paper jams
The ip90 is very fragile on the top center. When you travel with it in luggage or anything on top of it, it bends the frame down so paper can't pass thru. The only repair is a new print engine which is around $120.00. Otherwise look inside the back with a flashlight to see if anything has fallen in to stop the paper.
Jul 07, 2009 | Office Equipment & Supplies
Paper in printer
Goto the link provided below. You will need to fill in the three drop down windows.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Select cateegory = Printers
Select product type = PIXMA iP Series
Select model = PIXMA iP90
Click GO
Start with Number,
1.) Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Continue down till issue is resolved.
Feb 12, 2008 | Canon PIXMA iP90 Mobile Printer
Open Questions:
Computers & Internet Logo
51 people viewed this question
Ekse
Alun Cox
