Question about Mitsuba DV5 Digital Camera
Mitsuba dv7 memory card does not work, camera doesn't recoginze it mitsuba dv7
  • Anonymous Aug 18, 2008
    My Mitsuba 300R does not recognize the card. Will only take pictures using the internal memory. Have not yet tried formatting using my PC and a card reader. I don't have a card reader, so will have to find a friend who does.
How do i format the card
Posted on Jan 28, 2009
  • Anonymous Jan 28, 2009
    how do i format the card
    President:
  • 1,950 Answers
Try formatting the card with your PC and an external card reader.
Posted on Mar 17, 2008
SOURCE:
WHAT IS A PROTECTED CARD MY GETTING IT ON MY MITSUBA DX 700
It's not the camera. Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 17, 2013 | Mitsuba DX700 16MP Interpolated Digital...
So i got this new Mitsuba DC500T (12.0 mega pixels) and it only saves up to four pictures then says memory full so I added a SD card of 8GB & it still has the same problem, please help.
Hi there! Make sure the SD card is not locked. There is a tiny slider on the side. If is in the "down" position, the card cannot have new files written onto it or deleted from it. Move the slide to the "up" position, then reinsert the card. You should now be able to take many, many photos.
Mar 13, 2011 | Mitsuba DC500T Digital Camera
When I insert the sd memory card into my Mitsuba dc500t digital camera, it won't function until I remove the memory card. Any suggestions as to why this occurs and how to correct the problem so I can...
On MEMORY Card Problem, Make SURE its the SMALL Insert SD Card you are using & Not just a SD Card!
I Have same Camers & it should fix your Problem to use from 2 to 8 GB Memory.
Good Luck,
Dan
Apr 21, 2010 | Mitsuba DC500T Digital Camera
Camera freezes up
Use a higher quality SD card. PNY or SanDisk usually works well with flash camcorders. Also make sure it's a HCSD card ( High Capacity ).
Apr 04, 2010 | Mitsuba DV9002 Flash Media Camcorder
When i put a memory card in the camera doesn't seem to work...but does when i take it out
When you take the card out, it's writing to the internal memory. You may need to reset the camera to get it to write to the memory card. Just go into the menu and find "reset"...follow the on-screen instructions. Then, remove the card, go back into the menu and find "format"...follow the instructions to erase the internal memory. Then, insert the card and all should work. From now on, don't use the internal memory.
Jan 26, 2010 | Mitsuba DC500T Digital Camera
How to switch from extended memory card
go to options>memory> there will be a setting that say "internal" or "external" click on external and then you'll be on the SD Card's memory
May 29, 2009 | Mitsuba Video Cameras
I dont know how to use my mitsuba DV9002
have you the software the camera???
if you givime the software i help you jejej
Jan 21, 2009 | Mitsuba DV9002 Flash Media Camcorder
Camcorder not reading memory card
It seems to be getting on for ten years old now - replacement would be cheaper than repair.
Apr 01, 2017 | Mitsuba DV5 Camcorder
I cant get the flash to work. i lost the instructions and i cannot find there website so maybe you could help me.
did you find any help with this mitsuba as i have one also that wont read the memory card. I dont have their address or anything.
May 22, 2008 | Mitsuba DV55 Camcorder
Mitsuba DV5 Digital Camera Logo
198 people viewed this question
Top Mitsuba Cameras Experts
Damen Wong
Damen Wong
Gene Haynes
Ravi
Are you a Mitsuba Camera Expert? Answer questions, earn points and help others
