Question about JVC HD-56G886 56" Rear Projection HDTV
JVC HD-56G887 wont turn on
I have an JVC HD-56G887 that will not turn on. I happened this weekend while I was away- so the wifes description was we were watching a dvd and then the tv turned off. When we turn on the TV, usually the blue light on the tv's power button comes on, then you here the tv warming up or the fan turning on and then within 20-30 seconds the tv comes on. Now, no blue light, but you here everything working then in 10-15 seconds the tv shuts down. I tried unplugging it and waiting for 30 minutes- tried disconneting everything and usuing just tv in the outlet, but nothing worked. Any advice??
  • ericD2 Jul 05, 2008
    We have had the same problem with our JVC HD 56G887. The service tech came out and replaced the lamp, it was still having the same problem. So he came back and took all the guts out, and we were without a TV for 3 weeks. He came back and said he thought he fixed it, pretty much replaced everything. That was 2 mos ago, and now it is doing it again. I want a new TV!!!!
  • jimkamis2 Nov 23, 2008
    Same deal. Works then it wont. Let it sit unpugged to 24 hours and it came on. Out again. took it to a repair shop, by the time they got around to it, it worked so they did nothing. Always happens during football season!!!
Your TVneeds to be serviced by a JVC authorized service center.
Posted on May 11, 2008
SOURCE:
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Car wont start after leaving key in ignition,ie went to start car, but phone rang, key in ignition, now wont start.this has happened my wife on several occasions. starts fine on a push
Check the fuse box for the starter relay, and pull out to check pins for corrosion / bad contact. The fact it start on a bump with the key on leads me to suspect the start / crank position of the electrics. Get a knowledgeable person to run through the crank circuit with a meter, also check the condition of earth straps and starter cables. Could be the ignition switch is faulty?
May 14, 2015 | 2006 Saab 9-3 2.0
Please,tell me how do I turn off my self timer on my JVC micro component UX-lp5
Press CLOCK/TIMER repeatedly to select "DAILY 1", "DAILY 2", or "DAILY 3", then press CANCEL. See page 2 of this manual.
Mar 27, 2013 | Audio Players & Recorders
Sharan wont start clicking behind dash
It sounds like the battery has failed from the description your wife gave you.
Oct 18, 2012 | Cars & Trucks
Hello, I have no sound on JVC AV-56P575. When
I have had the same problem. It usually happens when changing from a non-HD channel to a HD. It has been doing since the purchase of the TV. Instead of going through the headache of a service call, I have been turning it off, wait a couple of minutes and then turn it back on. The sound returns and the issue will not repeat itself for at least a couple of weeks.
Dec 20, 2009 | JVC AV-56P575 56" Rear Projection...
I have a JVC HD-56G787 that I need a mirror for. Are they available? This is a new TV that was delivered several years ago with a broken mirror.
The mirror is available:
Manufacturer JVC Part Number LC33055-006A Description MIRROR List $241.49
The mirror wholesales for about 160 and retails for the above price.
You now have the part number and if you search the internet you may find there.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 20, 2009 | JVC HD-56G787 Television
How do i install my new lamp light
there is a panel either on the side or back of tv. unscrew that then you have a cartridge that needs tobe unscrewed. thn remove bulb and click in new one
May 20, 2009 | Televison & Video
JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
Dec 23, 2008 | JVC HD-52G787 52" Projection Television
JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
Jan 30, 2008 | JVC AV-56WP30 56" Rear Projection...
JVC HD-56G886 56" Rear Projection HDTV Logo
892 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
