Question about Epson Stylus Photo 820 InkJet Printer
Photo Stylus 820 Print Problem w/Vista
Went to print my tax returns with a new Vista driven Dell and not getting a print. Any help will be appreciated.
  • swansonsm Aug 14, 2008
    Epson stylus photo 820 printer- running on Vista powered HP Pavilion dv 6000. Printer will self test when asked (off-line). 820 does everything but print the requested document. Loaded new Vista driver, still nothing. Changed usb cable. Still nothing. Moved usb connection to other locations on the hub. Still nothing. Moved to USB connection directly on the laptop. Nada.
    Ideas?
    Genius:
  • 3,587 Answers
You might need new drivers..check here for them
Posted on Mar 17, 2008
SOURCE:
Have not used printer in a while. Installed new ink cartridge and Photo 820 will not print anything.
its common...just reinstall d software and reinsert the catridge properly so as to have prinouts accordingly :)
Sep 06, 2011 | Epson Stylus Photo 820 InkJet Printer
I want to install the Epson stylus 820 to my Dell computer. My computer doesn't recognize the printer.
the printer drivers are available here
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14409&prodoid=22966687&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=19&y=5
It is only compatible with win xp or older o/s so if your dell is using vista or win 7 it won't work.
Nov 04, 2009 | Epson Stylus Photo 820 InkJet Printer
Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Jul 12, 2009 | Epson Stylus Photo 820 InkJet Printer
Epson stylus D88 print problem (Serial no gsct240100)
Are you still using the win 98 drivers? Try downloading the latest vista drivers from Epson support:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Please take a moment to rate this solution. Thanks.
Mar 06, 2009 | Epson Stylus D88 InkJet Photo Printer
How to get Epson R300 stylus monitor to work in Vista
I have the same problem with my stylus C88. Epson never did provide Vista drivers so I have never found a way to get the Epson software to work with Vista. The print driver does work so you will be able to print but you'll have to clean the nozzle manually by pushing the button on the printer rather than using the Epson Monitor. Sorry.
Jan 25, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson stylus photo 820 printer hard rail problem?
I have had this happen quite often on different Epson printers and found it is not worth the time or bother to fix this due to the cost.
Sep 29, 2008 | Epson Stylus Photo 820 InkJet Printer
Printing problem
I uninstalled and reinstalled the printer and now it prints fine, though the paper jammed twice for no apparent reason. Guess it's time for a new printer.
Aug 23, 2008 | Epson Stylus Photo 820 InkJet Printer
Print quality
it is possile that your driver is for XP only, if you can confirm that it is running very well previously w/c i suspect try downloading a letest version in Vista platform,
wrong driver can sometimes do this
hope this helps
Aug 08, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stulus photo 820
A very strange effect new to me (and I'm ****** old). All I can suggest is to uninstall the printer, reboot and reinstall. Report back.
Apr 06, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson Stylus Photo 820 InkJet Printer Logo
47 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
